REST API reference
Retrieve event catalog definitions
GET /support/ems/messages
Retrieves the event catalog definitions.
  • event catalog show
description
string
query
False
Filter by description
deprecated
boolean
query
False
Filter by deprecated
snmp_trap_type
string
query
False
Filter by snmp_trap_type
corrective_action
string
query
False
Filter by corrective_action
name
string
query
False
Filter by name
severity
string
query
False
Filter by severity
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 3,
  "records": [
      "corrective_action": "string",
      "deprecated": 1,
      "description": "string",
      "name": "callhome.spares.low",
      "severity": "error",
      "snmp_trap_type": "standard"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
records
_links
_links
corrective_action
string
Corrective action
deprecated
boolean
Is deprecated?
description
string
name
string
Name of the event.
severity
string
Severity
snmp_trap_type
string
SNMP trap type
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
