Retrieve an SVM peer permission instance
GET /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Retrieves the SVM peer permission instance.
Related ONTAP commands
vserver peer permission show
Example
The following example shows how to retrieve the parameters for an SVM peer permission.
GET "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
Learn more
cluster_peer.uuid |
string |
path |
True |
Peer cluster UUID |
svm.uuid |
string |
path |
True |
SVM UUID |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
Status: 200, Ok
| Name | Type | Description |
_links |
applications |
array[string] |
A list of applications for an SVM peer relation. |
cluster_peer |
Peer cluster details |
svm |
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*". |
"href": "/api/resourcelink"
"applications": [
"snapmirror",
"flexcache"
"cluster_peer": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345574 |
Failed to find the SVM or volume name with UUID. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster_peer
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
