Retrieve SVM peer permissions
GET /svm/peer-permissions
Retrieves the list of SVM peer permissions.
Related ONTAP commands
vserver peer permission show
The following examples show how to retrieve a collection of SVM peer permissions based on a query.
Retrieves a list of SVM peer permissions of a specific local SVM
GET "/api/svm/peer-permissions/?svm.name=VS1"
Retrieves a list of SVM peer permissions of a specific cluster peer
GET "/api/svm/peer-permissions/?cluster_peer.name=cluster2"
Learn more
cluster_peer.uuid |
string |
query |
False |
Filter by cluster_peer.uuid |
cluster_peer.name |
string |
query |
False |
Filter by cluster_peer.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
applications |
string |
query |
False |
Filter by applications |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[svm_peer_permission] |
"next": {
"href": "/api/resourcelink"
"records": [
"applications": [
"snapmirror",
"flexcache"
"cluster_peer": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345574 |
Failed to find the SVM or volume name with UUID. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster_peer
Peer cluster details
_links |
name |
string |
uuid |
string |
svm
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".
_links |
name |
string |
The name of the SVM. |
uuid |
string |
svm_peer_permission
Manage SVM peer permissions.
_links |
applications |
array[string] |
A list of applications for an SVM peer relation. |
cluster_peer |
Peer cluster details |
svm |
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*". |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
