Manage CIFS shares
Overview
Before any users or applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permissions. CIFS share is a named access point in a volume which is tied to the CIFS server on the SVM. Before creating a CIFS share make sure that the path is valid within the scope of the SVM and that it is reachable.
Permissions can be assigned to this newly created share by specifying the 'acls' field. When a CIFS share is created, ONTAP creates a default ACL for this share with 'Full-Control' permissions for an 'Everyone' user.
Creating a CIFS share
To create a CIFS share for a CIFS server, use the following API. Note the return_records=true query parameter used to obtain the newly created entry in the response.
# The API:
POST /api/protocols/cifs/shares
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/shares?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"access_based_enumeration\": false, \"acls\": [ { \"permission\": \"no_access\", \"type\": \"unix_user\", \"user_or_group\": \"root\" } ], \"change_notify\": true, \"comment\": \"HR Department Share\", \"encryption\": false, \"home_directory\": false, \"name\": \"TEST\", \"oplocks\": true, \"path\": \"/\", \"svm\": { \"name\": \"vs1\", \"uuid\": \"000c5cd2-ebdf-11e8-a96e-0050568ea3cb\" }, \"unix_symlink\": \"local\"}"
# The response:
"num_records": 1,
"records": [
"svm": {
"uuid": "000c5cd2-ebdf-11e8-a96e-0050568ea3cb",
"name": "vs1"
"name": "TEST",
"path": "/",
"comment": "HR Department Share",
"home_directory": false,
"oplocks": true,
"access_based_enumeration": false,
"change_notify": true,
"encryption": false,
"unix_symlink": "local",
"acls": [
"user_or_group": "root",
"type": "unix_user",
"permission": "no_access",
"winsid_unixId": "0"
Retrieving CIFS Shares for all SVMs in the cluster
# The API:
GET /api/protocols/cifs/shares
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/shares?fields=*&return_records=true&return_timeout=15" -H "accept application/hal+json"
# The response:
"records": [
"svm": {
"name": "vs1",
"href": "/api/svm/svms/000c5cd2-ebdf-11e8-a96e-0050568ea3cb"
"name": "admin$",
"path": "/",
"oplocks": false,
"change_notify": false,
"volume": {
"name": "vol1",
"uuid": "4e06f1bc-1ddc-42e2-abb2-f221c6a2ab2a"
"href": "/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/admin%24"
"svm": {
"name": "vs1",
"name": "c$",
"path": "/",
"oplocks": true,
"acls": [
"user_or_group": "BUILTIN\\Administrators",
"type": "windows",
"permission": "full_control"
"volume": {
"name": "vol1",
"href": "/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/c%24"
"svm": {
"name": "vs1",
"name": "ipc$",
"path": "/",
"oplocks": false,
"volume": {
"name": "vol1",
"href": "/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/ipc%24"
"svm": {
"name": "vs1",
"name": "TEST",
"path": "/",
"oplocks": true,
"acls": [
"user_or_group": "Everyone",
"type": "windows",
"volume": {
"name": "vol1",
"href": "/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/TEST"
"num_records": 4,
"href": "/api/protocols/cifs/shares?fields=*&return_records=true&return_timeout=15"
Retrieving all CIFS Shares for all SVMs in the cluster for which the acls are configured for a "root" user
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/shares?acls.user_or_group=root&fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"name": "TEST",
"path": "/",
"oplocks": true,
"acls": [
"type": "windows",
"volume": {
"name": "vol1",
"num_records": 1
Retrieving a specific CIFS share configuration for an SVM
The configuration being returned is identified by the UUID of its SVM and the name of the share.
# The API:
GET /api/protocols/cifs/shares/{svm.uuid}/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/TEST" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
"name": "TEST",
"path": "/",
"oplocks": true,
"acls": [
"type": "windows",
"volume": {
"name": "vol1",
Updating a specific CIFS share for an SVM
The CIFS share being modified is identified by the UUID of its SVM and the CIFS share name. The CIFS share ACLs cannot be modified with this API.
# The API:
PATCH /api/protocols/cifs/shares/{svm.uuid}/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/TEST" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"access_based_enumeration\": true, \"change_notify\": true, \"comment\": \"HR Department Share\", \"encryption\": false, \"oplocks\": true, \"path\": \"/\", \"unix_symlink\": \"widelink\"}"
Removing a specific CIFS share for an SVM
The CIFS share being removed is identified by the UUID of its SVM and the CIFS share name.
# The API:
DELETE /api/protocols/cifs/shares/{svm.uuid}/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/shares/000c5cd2-ebdf-11e8-a96e-0050568ea3cb/test" -H "accept: application/json"
