Manage cluster-wide SNMP configuration
Overview
Cluster wide SNMP configuration. You can configure or retrieve the following SNMP parameters using this endpoint:
enable or disable SNMP
enable or disable SNMP authentication traps
Disables SNMP protocol in the cluster.
# The API:
PATCH "/api/support/snmp"
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://<mgmt-ip>/api/support/snmp" -d '{"enabled":"false"}'
# The response
200 OK
### Enables SNMP authentication traps in the cluster.
The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://+++<mgmt-ip>+++/api/support/snmp" -d '{"auth_traps_enabled":"true"}'+++</mgmt-ip>+++
The response
200 OK
Enables SNMP protocol and SNMP authentication traps in the cluster.
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X PATCH "https://+++<mgmt-ip>+++/api/support/snmp" -d '{"enabled":"true", "auth_traps_enabled":"true"}'+++</mgmt-ip>+++
# The response
200 OK
