Update an NTP server configuration after validation
PATCH /cluster/ntp/servers/{server}
Updates the configuration of an NTP server used by the ONTAP cluster after validation. Patchable fields are:
version -
key.id -
authentication_enabled
If authentication_enabled is modified to false, the associated NTP key is removed from the server instance.
If authentication_enabled is modified to true, you must provide an NTP key ID in the PATCH body.
Related ONTAP commands
cluster time-service ntp server modify
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
server |
string |
path |
True |
Server address or host name |
Request Body
| Name | Type | Description |
_links |
authentication_enabled |
boolean |
Set NTP symmetric authentication on (true) or off (false). |
key |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
Example request
"href": "/api/resourcelink"
"authentication_enabled": 1,
"key": {
"id": 10
"version": "auto"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097163 |
NTP server address was invalid. |
2097164 |
2097165 |
Could not resolve NTP server hostname. |
2097166 |
NTP server address query returned no valid IP addresses. |
2097167 |
Failed to connect to NTP server. |
2097169 |
NTP server provided was not synchronized. |
2097174 |
NTP server provided had too high of root distance. |
2097177 |
NTP server provided had an invalid stratum. |
2097181 |
2097182 |
2097183 |
NTP symmetric key authentication cannot be used for a node not in a cluster. |
2097185 |
NTP key authentication failed for the provided key. |
2097188 |
An invalid key identifier was provided. Identifiers must be in the range from 1 to 65535. |
2097193 |
An unknown key was provided. |
2097194 |
The field "authentication_enabled" cannot be false when the field NTP key is given. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ntp_key_reference
_links |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
ntp_server
_links |
boolean |
key |
version |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
