Update a schedule
PATCH /cluster/schedules/{uuid}
Updates a schedule. Note that you cannot modify a cron field of an interval schedule, or the interval field of a cron schedule.
Learn more
uuid |
string |
path |
True |
Schedule UUID |
Request Body
| Name | Type | Description |
_links |
cron |
Details for schedules of type cron. |
interval |
string |
An ISO-8601 duration formatted string. |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
Example request
"href": "/api/resourcelink"
"cron": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"interval": "P1DT2H3M4S",
"type": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
458788 |
The schedule specified is not a valid schedule. |
459760 |
459761 |
Schedule cannot be modified on this cluster because it is replicated from the remote cluster. |
460783 |
As this is a MetroCluster configuration and the local cluster is waiting for switchback, changes to non-system schedules are not allowed. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
The cluster that owns the schedule. Defaults to the local cluster.
name |
string |
Cluster name |
uuid |
string |
Cluster UUID |
cron
days |
array[integer] |
The days of the month the schedule runs. Leave empty for all. |
hours |
array[integer] |
The hours of the day the schedule runs. Leave empty for all. |
minutes |
array[integer] |
The minutes the schedule runs. Required on POST for a cron schedule. |
months |
array[integer] |
The months of the year the schedule runs. Leave empty for all. |
weekdays |
array[integer] |
The weekdays the schedule runs. Leave empty for all. |
schedule
Complete schedule information
_links |
cron |
interval |
string |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
