      Re-order a CIFS home directory search path
PATCH /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Reorders a CIFS home directory search path.
Related ONTAP commands
cifs server home-directory search-path reorder
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
index  |
integer  |
path  |
True  |
Home directory search path index  |
new_index  |
integer  |
query  |
False  |
New position for the home directory search path  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655463  |
Failed to reorder the search-path because the new-index is invalid. It cannot be '0' and it cannot go beyond the current entries  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
