Update a share-level ACL on a CIFS share
PATCH /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Updates a share-level ACL on a CIFS share.
Related ONTAP commands
vserver cifs share access-control modify
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
share |
string |
path |
True |
Share name |
user_or_group |
string |
path |
True |
User or group name |
type |
string |
path |
True |
User or group type |
Request Body
| Name | Type | Description |
_links |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
Example request
"href": "/api/resourcelink"
"permission": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655516 |
The share ACL does not exist for given user and share |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
The permissions that users and groups have on a CIFS share.
_links |
permission |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
