Update a UNIX symbolic link mapping for CIFS clients
PATCH /protocols/cifs/unix-symlink-mapping/{svm.uuid}/{unix_path}
Updates the UNIX symbolic link mapping for CIFS clients.
Related ONTAP commands
vserver cifs symlink modify
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
unix_path |
string |
path |
True |
UNIX symbolic link path |
Request Body
| Name | Type | Description |
_links |
svm |
target |
Example request
"href": "/api/resourcelink"
"svm": {
"name": "svm1",
"target": {
"locality": "string",
"path": "/dir1/dir2/",
"server": "ENGCIFS",
"share": "ENG_SHARE"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655573 |
Failed to modify the symlink mapping to target path because it contains illegal characters or is too long |
655575 |
Failed to modify the symlink mapping to target server because it contains illegal characters or is too long |
655547 |
Failed to modify symlink mapping becasue administrative share cannot be used as target share |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cifs_target
home_directory |
boolean |
Specify if the destination share is a home directory. |
locality |
string |
Specifies whether the CIFS symbolic link is a local link or wide link. The following values are supported:
path |
string |
Specifies the CIFS path on the destination to which the symbolic link maps. The final path is generated by concatenating the CIFS server name, the share name, the cifs-path and the remaining path in the symbolic link left after the prefix match. This value is specified by using a UNIX-style path name. The trailing forward slash is required for the full path name to be properly interpreted. |
server |
string |
Specifies the destination CIFS server where the UNIX symbolic link is pointing. This field is mandatory if the locality of the symbolic link is 'widelink'. You can specify the value in any of the following formats:
share |
string |
Specifies the CIFS share name on the destination CIFS server to which the UNIX symbolic link is pointing. |
cifs_symlink_mapping
ONTAP allows for both CIFS and NFS access to the same datastore. This datastore can contain symbolic links created by UNIX clients which can point anywhere from the perspective of the UNIX client. To Access such UNIX symlink from CIFS share, we need to create a CIFS symbolic link path mapping from a UNIX symlink and target it as a CIFS path.
_links |
svm |
target |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
