Update export policy properties
PATCH /protocols/nfs/export-policies/{id}
Updates the properties of an export policy to change an export policy name or replace all export policy rules.
Related ONTAP commands
vserver export-policy rename -
vserver export-policy rule delete -
vserver export-policy rule create
Learn more
id |
integer |
path |
True |
Export Policy ID |
Request Body
| Name | Type | Description |
_links |
id |
integer |
Export Policy ID |
name |
string |
Export Policy Name |
rules |
array[export_rule] |
Rules of the Export Policy. |
svm |
Example request
"href": "/api/resourcelink"
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703950 |
Failed to rename ruleset |
1703952 |
Invalid ruleset name provided. No spaces are allowed in a ruleset name |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_client
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rule
_links |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
clients |
array[export_client] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
export_policy
_links |
id |
integer |
Export Policy ID |
name |
string |
rules |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
