Update iSCSI credentials
PATCH /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Updates specified iSCSI credentials.
Related ONTAP commands
vserver iscsi security add-initiator-address-ranges -
vserver iscsi security default -
vserver iscsi security modify -
vserver iscsi security remove-initiator-address-ranges
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of an SVM. |
initiator |
string |
path |
True |
The iSCSI initiator of the credentials object. |
add_initiator_addresses |
boolean |
query |
False |
If true, the initiator addresses in the body merge into the existing addresses in the iSCSI security object rather than replace the existing addresses.
remove_initiator_addresses |
boolean |
query |
False |
If true, the initiator addresses in the body are removed from the existing addresses in the iSCSI security object rather than replace the existing addresses.
Request Body
| Name | Type | Description |
_links |
authentication_type |
string |
The iSCSI authentication type. Required in POST and optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator_address |
Initiator address ranges. |
svm |
Example request
"href": "/api/resourcelink"
"authentication_type": "string",
"chap": {
"inbound": {
"password": "string",
"user": "string"
"outbound": {
"user": "string"
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
2621706 |
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5374145 |
The iSCSI security password must contain an even number of valid hex digits. |
5374147 |
The CHAP inbound and outbound passwords must be different. |
5374149 |
The inbound user and password properties are required for CHAP authentication. |
5374150 |
Outbound CHAP authentication requires an outbound password. |
5374155 |
The functionality is not supported for the default security credential. |
5374855 |
The value for property |
5374856 |
5374895 |
The iSCSI security credential does not exist on the specified SVM. |
5374900 |
Setting the CHAP authentication properties are not supported with authentication types none or deny. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
inbound
Inbound CHAP credentials.
password |
string |
The inbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
password |
string |
The outbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. |
chap
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
family |
string |
IPv4 or IPv6 |
start |
string |
initiator_address
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
iscsi_credentials
_links |
string |
chap |
initiator_address |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
