Update an IPsec policy
PATCH /security/ipsec/policies/{uuid}
Updates a specific IPsec policy.
Related ONTAP commands
security ipsec policy modify
Learn more
uuid |
string |
path |
True |
IPsec policy UUID |
Request Body
| Name | Type | Description |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
local_endpoint |
Local endpoint for the IPsec policy. |
name |
string |
IPsec policy name. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
Example request
"local_endpoint": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24",
"port": "23"
"name": "string",
"protocol": "17",
"remote_endpoint": {
"family": "string",
"netmask": "24",
"port": "23"
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257097 |
Internal error. Failed to update the IPsec policy. |
66257099 |
Only one protocol can be specified. |
66257100 |
Only one local port can be specified. |
66257101 |
Only one remote port can be specified. |
66257110 |
Failed to create a policy sequencing value. |
66257113 |
Only one local IP subnet can be specified. |
66257114 |
Only one remote IP subnet can be specified. |
66257115 |
Port ranges containing more than one port are not supported. |
66257116 |
IPsec policy with the specified UUID was not found. |
66257120 |
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask). |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
local_endpoint
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
remote_endpoint
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
port |
string |
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ipsec_policy
IPsec policy object.
enabled |
boolean |
local_endpoint |
name |
string |
protocol |
string |
remote_endpoint |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
