Update a primary key server
PATCH /security/key-managers/{uuid}/key-servers/{server}
Updates a key server.
Related ONTAP commands
security key-manager external modify-server
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
path |
True |
Key server configured in the external key manager. |
Request Body
| Name | Type | Description |
_links |
connectivity |
This property returns the key server connectivity state on all nodes of the cluster. The state is returned for a node only if the connectivity is not in an available state on that node.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
Example request
"href": "/api/resourcelink"
"connectivity": {
"records": [
"node": {
"name": "node1",
"state": "not_responding"
"password": "password",
"timeout": 60,
"username": "username"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536828 |
External key management is not enabled for the SVM. |
65536843 |
The key management server is not configured for the SVM. |
65536845 |
Missing username. |
65536846 |
Missing password. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
key_server_state
The state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability |
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
records |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
_links |
connectivity |
password |
string |
timeout |
integer |
username |
string |
key_server
_links |
connectivity |
password |
string |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
