Update the access level for a REST API path or command/command directory path
PATCH /security/roles/{owner.uuid}/{name}/privileges/{path}
Updates the privilege level for a REST API path.
Required parameters
owner.uuid- UUID of the SVM that houses this role. -
name- Name of the role to be updated. -
path- Constituent REST API path whose access level has to be updated. -
access- Access level for the path (one of "all", "readonly", or "none")
Related ONTAP commands
security login rest-role modify
owner.uuid  |
string  |
path  |
True  |
Role owner UUID  |
name  |
string  |
path  |
True  |
Role name  |
path  |
string  |
path  |
True  |
REST API path  |
Request Body
| Name | Type | Description |
_links  |
access  |
string  |
Access level for the REST endpoint.  |
Example request
      "href": "/api/resourcelink"
  "access": "readonly"
Status: 200, Ok
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
_links  |
access  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
