Update the SSH server setting for a cluster
PATCH /security/ssh
Updates the SSH server setting for a cluster.
Optional parameters
ciphers- Encryption algorithms for the payload -
key_exchange_algorithms- SSH key exchange algorithms -
mac_algorithms- MAC algorithms -
max_authentication_retry_count- Maximum authentication retries allowed before closing the connection -
connections_per_second- Maximum allowed connections per second -
max_instances- Maximum allowed connections per node -
per_source_limit- Maximum allowed connections from the same client host
Related ONTAP commands
security ssh -
security protocol ssh
Learn more
return_records  |
boolean  |
query  |
False  |
The default is false. If set to true, the records are returned.  |
Request Body
| Name | Type | Description |
_links  |
ciphers  |
array[string]  |
Ciphers for encrypting the data.  |
connections_per_second  |
integer  |
Maximum connections allowed per second.  |
key_exchange_algorithms  |
array[string]  |
Key exchange algorithms.  |
mac_algorithms  |
array[string]  |
MAC algorithms.  |
max_authentication_retry_count  |
integer  |
Maximum authentication retries allowed before closing the connection.  |
max_instances  |
integer  |
Maximum possible simultaneous connections.  |
per_source_limit  |
integer  |
Maximum connections from the same client host.  |
Example request
      "href": "/api/resourcelink"
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "diffie_hellman_group14_sha1"
  "mac_algorithms": [
    "hmac_sha1",
    "hmac_sha2_512_etm"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10682372  |
There must be at least one key exchange algorithm associated with the SSH configuration.  |
10682373  |
There must be at least one cipher associated with the SSH configuration.  |
10682375  |
Failed to modify SSH key exchange algorithms.  |
10682378  |
Failed to modify SSH ciphers.  |
10682399  |
Key exchange algorithm not supported in FIPS enabled mode.  |
10682400  |
Failed to modify SSH MAC algorithms.  |
10682401  |
MAC algorithm not supported in FIPS enabled mode.  |
10682403  |
There must be at least one MAC algorithm with the SSH configuration.  |
10682413  |
Failed to modify maximum authentication retry attempts.  |
10682413  |
10682418  |
Cipher not supported in FIPS enabled mode.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
cluster_ssh_server
_links  |
ciphers  |
array[string]  |
integer  |
array[string]  |
mac_algorithms  |
array[string]  |
MAC algorithms.  |
integer  |
max_instances  |
integer  |
per_source_limit  |
integer  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
