Update a SnapMirror relationship
PATCH /snapmirror/relationships/{uuid}
Updates a SnapMirror relationship. This API is used to initiate SnapMirror operations such as "initialize", "resync", "break", "quiesce", and "resume" by specifying the appropriate value for the "state" field. It is also used to modify the SnapMirror policy associated with the specified relationship.
Related ONTAP commands
snapmirror modify -
snapmirror initialize -
snapmirror resync -
snapmirror break -
snapmirror quiesce -
snapmirror resume
The following examples show how to perform the SnapMirror "resync", "initialize", "resume", "quiesce", and "break" operations.
Performing a SnapMirror "resync"
PATCH "/api/snapmirror/relationships/98bb2608-fc60-11e8-aa13-005056a707ff/" '{"state":"snapmirrored"}'
Performing a SnapMirror "initialize"
Performing a SnapMirror "resume"
Performing a SnapMirror "quiesce"
PATCH "/api/snapmirror/relationships/98bb2608-fc60-11e8-aa13-005056a707ff" '{"state":"paused"}'
Performing a SnapMirror "break"
PATCH "/api/snapmirror/relationships/98bb2608-fc60-11e8-aa13-005056a707ff" '{"state":"broken_off"}'
Updating an associated SnapMirror policy
PATCH "/api/snapmirror/relationships/9e922e65-1818-11e9-8b22-005056bbee73/" '{"policy": { "name" : "MirrorAndVaultDiscardNetwork"}}'
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
uuid |
string |
path |
True |
Relationship UUID |
failover |
boolean |
query |
False |
If this parameter is set, validation and failover will occur to the Snapmirror relationship destination endpoint. Any other fields specified with this parameter will be ignored. |
validate_only |
boolean |
query |
False |
Validate the operation and its parameters, without actually performing the operation. |
force-failover |
boolean |
query |
False |
If this parameter is set, failover will occur to the SVM DR relationship endpoint, overriding the validation errors. |
Request Body
| Name | Type | Description |
_links |
destination |
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume or FlexGroup volume endpoints can optionally specify the "cluster" property. A POST request to establish a SnapMirror relationship when the source SVM and the destination SVM are not peered, must specify the "cluster" property. |
exported_snapshot |
string |
Snapshot copy exported to clients on destination. |
healthy |
boolean |
Is the relationship healthy? |
lag_time |
string |
Time since the exported Snapshot copy was created. |
policy |
Basic policy information of the relationship. |
preserve |
boolean |
Set to true on resync to preserve Snapshot copies on the destination that are newer than the latest common Snapshot copy. This property is applicable only for relationships with FlexGroup or FlexVol endpoints and when the PATCH state is being changed to "snapmirrored". |
quick_resync |
boolean |
Set to true to reduce resync time by not preserving storage efficiency. This property is applicable only for relationships with FlexVol endpoints and when the PATCH state is being changed to "snapmirrored". |
recover_after_break |
boolean |
Set to true to recover from a failed SnapMirror break operation on a FlexGroup relationship. This restores all destination FlexGroup constituents to the latest Snapshot copy, and any writes to the read-write constituents are lost. This property is applicable only for SnapMirror relationships with FlexGroup endpoints and when the PATCH state is being changed to "broken_off". |
restore_to_snapshot |
string |
Specifies the Snapshot copy to restore to on the destination during the break operation. This property is applicable only for SnapMirror relationships with FlexVol endpoints and when the PATCH state is being changed to "broken_off". |
source |
state |
string |
State of the relationship. To initialize the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or "in-sync" for relationships with a policy of type "sync". To break the relationship, PATCH the state to "broken_off". To resync the broken relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or "in_sync" for relationships with a policy of type "sync". To pause the relationship, suspending further transfers, PATCH the state to "paused". To resume transfers for a paused relationship, PATCH the state to "snapmirrored" or "in_sync". The entries "in_sync", "out_of_sync", and "synchronizing" are only applicable to relationships with a policy of type "sync". A PATCH call on the state change only triggers the transition to the specified state. You must poll on the "state", "healthy" and "unhealthy_reason" properties using a GET request to determine if the transition is successful. To automatically initialize the relationship when specifying “create_destination”, set the state to “snapmirrored” for relationships with a policy of type "async" or "in_sync" for relationships with a policy of type "sync". |
transfer |
Basic information on the current transfer. |
unhealthy_reason |
array[snapmirror_error] |
Reason the relationship is not healthy. It is a concatenation of up to four levels of error messages. |
uuid |
string |
Example request
"href": "/api/resourcelink"
"destination": {
"cluster": {
"name": "cluster1",
"svm": {
"name": "svm1",
"exported_snapshot": "string",
"lag_time": "PT8H35M42S",
"policy": {
"name": "Asynchronous",
"type": "string",
"restore": null,
"restore_to_snapshot": "string",
"source": {
"cluster": {
"name": "cluster1",
"svm": {
"name": "svm1",
"state": "snapmirrored",
"transfer": {
"state": "string",
"unhealthy_reason": [
"code": "6621444",
"message": "Failed to complete update operation on one or more item relationships.",
"parameters": []
"code": "6621445",
"message": "Group Update failed",
"parameters": []
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303825 |
Could not retrieve information for the SnapMirror policy type |
13303817 |
Unknown value for the SnapMirror state |
13303829 |
Invalid state |
13303830 |
Transient state |
13303831 |
Invalid state for async SnapMirror relationship |
13303834 |
Given input valid only for FlexGroup SnapMirror relationship |
13303835 |
Given flag is valid only when PATCH state is broken_off |
13303836 |
Given flag is valid only when PATCH state is snapmirrored or in_sync |
13303818 |
Invalid state transition requested |
13303828 |
Given state change is not possible for SVM SnapMirror relationship |
13303833 |
Requested state change is not possible |
13303832 |
SnapMirror relationship is already initialized |
13303824 |
Quiescing the SnapMirror relationship has failed |
13303826 |
Required environment variables are not set |
13303827 |
Internal Error |
13303823 |
Quiesce operation timed out |
13303821 |
Invalid SnapMirror policy name/UUID |
13303819 |
Could not retrieve SnapMirror policy information |
13303851 |
Cannot modify attributes of SnapMirror restore relationship |
13303816 |
Could not retrieve state or status values |
13303837 |
Given flags are valid only if SnapMirror state change is requested |
6619546 |
Destination must be a dp volume |
13303808 |
Transition to broken_off state failed |
13303809 |
Transition to paused state failed |
13303810 |
Transition to snapmirrored state failed |
13303811 |
Transition from paused state failed |
13303820 |
SnapMirror policy was successfully updated, state transition failed |
13303856 |
SVM is not configured with any data protocol |
13303857 |
SVM is not configured with any network interface |
13303858 |
Internal error. Failed to check LIF and protocols details for SVM |
13303859 |
Internal error. SVM Failover operation failed. SVM operational state is unavailable. |
13303865 |
Modifying the specified SnapMirror policy is not supported. |
13303866 |
Cannot use the specified policy to modify the policy of the relationship. |
13303867 |
Modifying the policy of an async-mirror or a vault relationship is not supported. |
13303884 |
LIF and protocols details are configured incorrectly for SVM. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
storage_service
enabled |
boolean |
This property indicates whether to create the destination endpoint using storage service. |
enforce_performance |
boolean |
Optional property to enforce storage service performance on the destination endpoint when the destination endpoint is used for read-write operations. This property is applicable to FlexVol volume and FlexGroup volume endpoints. |
name |
string |
Optional property to specify the storage service name for the destination endpoint. This property is considered when the property "create_destination.storage_service.enabled" is set to "true". When the property "create_destination.storage_service.enabled" is set to "true" and the "create_destination.storage_service.name" for the endpoint is not specified, then ONTAP selects the highest storage service available on the cluster to provision the destination endpoint. This property is applicable to FlexVol volume and FlexGroup volume endpoints.
tiering
policy |
string |
Optional property to specify the destination endpoint's tiering policy when "create_destination.tiering.supported" is set to "true". This property is applicable to FlexVol volume and FlexGroup volume endpoints. This property determines whether the user data blocks of the destination endpoint in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of the destination endpoint volume blocks increases if they are accessed frequently and decreases when they are not. all ‐ This policy allows tiering of both destination endpoint Snapshot copies and the user transfered data blocks to the cloud store as soon as possible by ignoring the temperature on the volume blocks. This tiering policy is not applicable for synchronous relationships. auto ‐ This policy allows tiering of both destination endpoint Snapshot copies and the active file system user data to the cloud store none ‐ Destination endpoint volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the destination endpoint volume Snapshot copies not associated with the active file system. The default tiering policy is "snapshot_only" for a FlexVol volume and "none" for a FlexGroup volume. |
supported |
boolean |
Optional property to enable provisioning of the destination endpoint volumes on FabricPool aggregates. This property is applicable to FlexVol volume and FlexGroup volume endpoints. Only FabricPool aggregates are used if this property is set to "true" and only non FabricPool aggregates are used if this property is set to "false". Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only do the destination endpoint volumes need to support tiering by using FabricPools, the "create_destination.tiering.policy" must not be "none". A destination endpoint that uses FabricPools but has a tiering "policy" of "none" supports tiering but will not tier any data. |
snapmirror_destination_creation
Use this object to provision the destination endpoint when establishing a SnapMirror relationship for a FlexVol volume, FlexGroup volume, or SVM. Given a source endpoint, the destination endpoint is provisioned in the SVM specified in the "destination.path" property. The SVM destination endpoint can only be provisioned on the local cluster. To provision the SVM destination endpoint use the optional "source.cluster.name" property to specify the remote cluster name or use the optional "source.cluster.uuid" property to specify the remote cluster UUID. When "create_destination.enabled" option is specified while making a POST for a SnapMirror relationship, the relationship can be automatically initialized by setting the "state" either to "snapmirrored" when the policy is of type "async" or to "in_sync" when the policy is of type "sync". The "destination.path" property must specify the destination endpoint path. For example, for FlexVol volume and FlexGroup volume, the "destination.path" can be specified as
enabled |
boolean |
Optional property to create the destination endpoint when establishing a SnapMirror relationship. It is assumed to be "false" if no other property is set and assumed to be "true" if any other property is set. |
storage_service |
tiering |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
cluster |
svm |
policy
_links |
name |
string |
type |
string |
uuid |
string |
transfer
_links |
bytes_transferred |
integer |
Bytes transferred. |
state |
string |
uuid |
string |
snapmirror_error
SnapMirror error
code |
integer |
Error code |
message |
string |
Error message |
parameters |
array[string] |
Parameters for the error message |
snapmirror_relationship
SnapMirror relationship information
_links |
destination |
exported_snapshot |
string |
healthy |
boolean |
lag_time |
string |
policy |
preserve |
boolean |
quick_resync |
boolean |
boolean |
string |
source |
state |
string |
transfer |
unhealthy_reason |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
