Update an aggregate specified by the UUID
PATCH /storage/aggregates/{uuid}
Updates the aggregate specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate add-disks -
storage aggregate mirror -
storage aggregate modify -
storage aggregate relocation start -
storage aggregate rename
Learn more
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202.  |
uuid  |
string  |
path  |
True  |
Aggregate UUID  |
disk_size  |
integer  |
query  |
False  |
If set, PATCH only selects disks of the specified size.  |
Request Body
| Name | Type | Description |
_links  |
block_storage  |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.  |
cloud_storage  |
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.  |
create_time  |
string  |
Timestamp of aggregate creation  |
data_encryption  |
dr_home_node  |
Node where the aggregate belongs after disaster recovery. The value for this field might differ from the 'node' field during switchover.  |
home_node  |
Node where the aggregate belongs after giveback. The value for this field might differ from the value of the 'node' field during takeover.  |
metric  |
The most recent sample of I/O metrics for the aggregate.  |
name  |
string  |
Aggregate name  |
node  |
Node where the aggregate currently resides.  |
space  |
state  |
string  |
Operational state of the aggregate  |
statistics  |
The real time I/O statistics for the aggregate.  |
uuid  |
string  |
Aggregate UUID  |
Example request
      "href": "/api/resourcelink"
  "block_storage": {
    "hybrid_cache": {
      "disk_count": 6,
      "raid_type": "string",
      "size": 1612709888,
      "used": 26501122
    "mirror": {
      "enabled": "",
      "state": "string"
    "plexes": [
        "name": "plex0"
    "primary": {
      "disk_count": 8,
      "disk_type": "fc",
      "raid_size": 16,
  "cloud_storage": {
    "stores": [
        "cloud_store": {
          "name": "store1",
        "used": 0
  "create_time": "2018-01-01 12:00:00 -0400",
  "dr_home_node": {
    "name": "node1",
  "home_node": {
    "name": "node1",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25 11:20:13 UTC"
  "name": "node1_aggr_1",
  "node": {
    "name": "node1",
  "space": {
    "block_storage": {
      "available": 10156560384,
      "full_threshold_percent": 0,
      "inactive_user_data": 304448,
      "size": 10156769280,
      "used": 2088960
    "cloud_storage": {
      "used": 402743264
    "efficiency": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "footprint": 608896
  "state": "string",
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "uuid": "string"
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262247  |
The value is invalid for the field.  |
460777  |
Failed to get information on the job.  |
786434  |
Cannot connect to node where the aggregate resides.  |
786435  |
Internal Error. Failed to create a communication handle.  |
786439  |
An aggregate already uses the specified name.  |
786447  |
Failed to modify aggregate.  |
786456  |
Failed to add disks to aggregate.  |
786458  |
Failed to rename aggregate.  |
786468  |
VLDB is offline.  |
786472  |
Node that hosts the aggregate is offline.  |
786479  |
Cannot find node ID for the node.  |
786730  |
Internal Error  |
786771  |
Aggregate does not exist.  |
786787  |
Aggregate is not online.  |
786808  |
Aggregate mirror failed.  |
786867  |
Specified aggregate resides on the remote cluster.  |
786911  |
Not every node in the cluster has the Data ONTAP version required for the feature.  |
786923  |
This operation is disallowed during pre-commit phase of 7-mode to clustered Data ONTAP transition.  |
786924  |
Internal Error for an aggregate that is in pre-commit phase of a 7-mode to clustered Data ONTAP transition.  |
786955  |
Modifying raidtype to raid_tec requires a minimum of six disks in the RAID Group.  |
786956  |
Modifying raidtype to raid_dp requires a minimum of four disks in the RAID Group.  |
786965  |
Spare Selection in userspace failed.  |
787046  |
Mirroring of a FabricPool is not allowed.  |
787092  |
The target field cannot be specified for this operation.  |
787144  |
Aggregate is not a FabricPool.  |
787156  |
Modifying the attributes of mirror object store is not allowed.  |
787169  |
Only one field can be modified per operation.  |
787170  |
Failed to patch the "block_storage.primary.disk_count" because the disk count specified is smaller than existing disk count.  |
787178  |
Unmirroring an aggregate with a PATCH operation is not supported.  |
2425736  |
No matching node found for the UUID provided.  |
13108106  |
Cannot run aggregate relocation because volume expand is in progress.  |
26542083  |
Destination node is at higher Data ONTAP version than source node.  |
26542084  |
Source node is at higher Data ONTAP version than destination node.  |
26542097  |
Unable to get D-blade ID of destination.  |
26542101  |
Unable to contact source node.  |
26542102  |
Unable to contact destination node.  |
26542120  |
A Vserver migrate operation is in progress. When the migrate operation completes, try the operation again.  |
26542121  |
A MetroCluster disaster recovery operation is in progress. When the recovery operation completes, try the operation again.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count  |
integer  |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'.  |
enabled  |
boolean  |
Aggregate uses HDDs with SSDs as a cache  |
raid_type  |
string  |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'.  |
size  |
integer  |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.  |
used  |
integer  |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.  |
mirror
enabled  |
boolean  |
Aggregate is SyncMirror protected  |
state  |
string  |
plex_reference
Plex
_links  |
name  |
string  |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
disk_count  |
integer  |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache.  |
disk_type  |
enum  |
The type of disk being used by the aggregate.  |
raid_size  |
integer  |
Option to specify the maximum number of disks that can be included in a RAID group.  |
raid_type  |
string  |
RAID type of the aggregate.  |
block_storage
hybrid_cache  |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.  |
mirror  |
plexes  |
array[plex_reference]  |
Plex reference for each plex in the aggregate.  |
primary  |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.  |
cloud_store
Cloud store
_links  |
name  |
string  |
uuid  |
string  |
cloud_storage_tier
cloud_store  |
Cloud store  |
used  |
integer  |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes.  |
cloud_storage
attach_eligible  |
boolean  |
Aggregate is eligible for a cloud store to be attached.  |
stores  |
array[cloud_storage_tier]  |
Configuration information for each cloud storage portion of the aggregate.  |
tiering_fullness_threshold  |
integer  |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations.  |
data_encryption
drive_protection_enabled  |
boolean  |
Aggregate uses self-encrypting drives with data protection enabled.  |
software_encryption_enabled  |
boolean  |
NetApp Aggregate Encryption enabled. All data in the aggregate is encrypted.  |
dr_home_node
name  |
string  |
uuid  |
string  |
home_node
_links  |
name  |
string  |
uuid  |
string  |
iops
other  |
integer  |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.  |
read  |
integer  |
Performance metric for read I/O operations.  |
total  |
integer  |
Performance metric aggregated over all types of I/O operations.  |
write  |
integer  |
Peformance metric for write I/O operations.  |
latency
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
throughput
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
metric
_links  |
duration  |
string  |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:  |
iops  |
The rate of I/O operations observed at the storage object.  |
latency  |
The round trip latency in microseconds observed at the storage object.  |
status  |
string  |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.  |
throughput  |
The rate of throughput bytes per second observed at the storage object.  |
timestamp  |
string  |
The timestamp of the performance data.  |
node
_links  |
name  |
string  |
uuid  |
string  |
block_storage
available  |
integer  |
Space available in bytes  |
full_threshold_percent  |
integer  |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated.  |
inactive_user_data  |
integer  |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **.  |
size  |
integer  |
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.  |
used  |
integer  |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata.  |
cloud_storage
used  |
integer  |
Used space in bytes in the cloud store. Only applicable for aggregate with a cloud store tier.  |
efficiency
Storage efficiency
logical_used  |
integer  |
Logical used  |
ratio  |
number  |
Data reduction ratio (logical_used / used)  |
savings  |
integer  |
Space saved by storage efficiencies (logical_used - used)  |
Storage efficiency that does not include the savings provided by Snapshot copies
logical_used  |
integer  |
Logical used  |
ratio  |
number  |
savings  |
integer  |
space
block_storage  |
cloud_storage  |
efficiency  |
Storage efficiency  |
efficiency_without_snapshots  |
Storage efficiency that does not include the savings provided by Snapshot copies  |
footprint  |
integer  |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.  |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
statistics
iops_raw  |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.  |
latency_raw  |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.  |
status  |
string  |
throughput_raw  |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.  |
timestamp  |
string  |
aggregate
_links  |
block_storage  |
cloud_storage  |
create_time  |
string  |
data_encryption  |
dr_home_node  |
home_node  |
metric  |
name  |
string  |
Aggregate name  |
node  |
space  |
state  |
string  |
statistics  |
uuid  |
string  |
Aggregate UUID  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
