Update disk ownership, change authentication keys, or sanitize disks
PATCH /storage/disks
Updates the encryption controls of self-encrypting disks.
Related ONTAP commands
storage encryption disk modify -data-key-id -
security key-manager key query -key-type NSE-AK
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
name |
string |
query |
True |
Disk name |
encryption_operation |
string |
query |
True |
Name of the operation to apply to encrypting disks.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1441795 |
Setting the data key ID to the manufacture secure ID is not allowed when in FIPS-compliance mode. |
14155777 |
The operation failed on one or more disks. |
14155778 |
No self-encrypting disks were specified. |
14155779 |
Status from a node shows that a conflicting operation has occurred. Some disk controls might have changed. |
14155780 |
Could not retrieve the required key ID from the key manager. |
