Update properties for a qtree
PATCH /storage/qtrees/{volume.uuid}/{id}
Updates properties for a specific qtree.
Related ONTAP commands
qtree modify -
qtree rename
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
volume.uuid |
string |
path |
True |
Volume UUID |
id |
string |
path |
True |
Qtree ID |
Request Body
| Name | Type | Description |
_links |
export_policy |
Export Policy |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
security_style |
string |
Security style. Valid in POST or PATCH. |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
Example request
"href": "/api/resourcelink"
"export_policy": {
"id": 100,
"name": "default"
"id": 1,
"name": "string",
"path": "/volume3/qtree1",
"security_style": "string",
"unix_permissions": 493
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
918235 |
A volume with UUID was not found. |
5242951 |
Export policy supplied does not belong to the specified export policy ID. |
5242955 |
The UUID of the volume is required. |
5242956 |
Failed to obtain qtree with ID. |
5242958 |
Failed to rename qtree in volume in SVM with ID. |
5242959 |
Successfully renamed qtree but modify failed. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
svm
Required in POST
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
Required in POST
_links |
name |
string |
The name of the volume. |
uuid |
string |
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_links |
export_policy |
Export Policy |
id |
integer |
name |
string |
path |
string |
security_style |
string |
unix_permissions |
integer |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
