Update SnapLock audit logs
PATCH /storage/snaplock/audit-logs/{svm.uuid}
Updates one of the following:
the audit log volume,
the attributes of the audit log volume present, or
archive the current audit log files
Related ONTAP commands
snaplock log modify
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
svm.uuid |
string |
path |
True |
SVM UUID |
Request Body
| Name | Type | Description |
_links |
log_archive |
log_volume |
Example request
"href": "/api/resourcelink"
"log_archive": {
"base_name": "string",
"expiry_time": "2058-06-04 19:00:00 UTC",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": 20000
"log_volume": {
"max_log_size": 20971520,
"retention_period": "P30M",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090344 |
If log_volume is specified, then log_archive must not be specified |
14090345 |
If log_archive.base_name is specified, then log_archive.archive must also be specified |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
log_archive
_links |
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
snaplock_log_file
_links |
archive |
boolean |
base_name |
string |
expiry_time |
string |
path |
string |
size |
integer |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
snaplock_log_volume
_links |
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_log
_links |
log_archive |
log_volume |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
