Update the SnapLock retention time of a file
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameter expiry_time expects the date in ISO 8601 format or infinite.
Related ONTAP commands
volume file retention set
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" </filename></dirpath> |
Request Body
| Name | Type | Description |
_links |
expiry_time |
string |
Expiry time of the file in date-time format. |
Example request
"href": "/api/resourcelink"
"expiry_time": "2058-06-04 19:00:00 UTC"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090347 |
File path must be in the format "/ |
14090348 |
Invalid Expiry time |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
snaplock_file_retention
_links |
expiry_time |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
