Write to an existing file with the supplied data
PATCH /storage/volumes/{volume.uuid}/files/{path}
Writes to an existing file with the supplied data or modifies the QoS policy of a file.
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Relative path of a file in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided. |
byte_offset |
integer |
query |
False |
How many bytes into the file to begin writing. Use -1 to append (default). |
overwrite |
bool |
query |
False |
If false, and the file exists, the write will fail. Default is false. |
stream_name |
string |
query |
False |
Name of stream associated with the file to write data to. |
data |
string |
formData |
False |
Data to write to the file. |
Request Body
| Name | Type | Description | ||
name |
string |
Name of the file. |
qos_policy |
The QoS policy for the file. Both traditional and adaptive QoS policies are supported. If both
Note that a QoS policy can be set on a file, or a file's volume, but not on both. |
size |
integer |
The size of the file, in bytes. |
target |
string |
The relative or absolute path contained in a symlink, in the form |
unix_permissions |
integer |
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). The first digit selects the set user ID(4), set group ID (2), and sticky (1) attributes. The second digit selects permissions for the owner of the file; the third selects permissions for other users in the same group; the fourth selects permissions for other users not in the group. |
Example request
"is_empty": "",
"is_junction": "",
"is_snapshot": "",
"is_vm_aligned": "",
"name": "test_file",
"qos_policy": {
"href": "/api/resourcelink"
"name": "qos1",
"size": 200,
"target": "some_directory/some_other_directory/some_file",
"unix_permissions": 493
Status: 200, Ok
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
metadata |
self |
_links
self |
qos_policy
The QoS policy for the file. Both traditional and adaptive QoS policies are supported. If both qos_policy.uuid and qos_policy.name properties are specified in the same request, they must refer to the same QoS policy. To remove the file from a QoS policy, set the property qos_policy.name in a PATCH request to an empty string "" or "none".
Files which are in use as a LUN cannot be assigned to a QoS policy, instead use PATCH on /storage/luns to assign a QoS policy for such files. |
_links |
name |
string |
The name of the QoS policy. To remove the file from a QoS policy, set this property to an empty string "" or set it to "none" in a PATCH request. |
uuid |
string |
The unique identifier of the QoS policy. Valid in PATCH. |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
file_info
Information about a single file.
name |
string |
Name of the file. |
qos_policy |
size |
integer |
target |
string |
unix_permissions |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
