Update an event destination
PATCH /support/ems/destinations/{name}
Updates an event destination.
Recommended optional properties
filters.name- New list of filters that should direct to this destination. The existing list is discarded. -
certificate- New certificate parameters when the destination type isrest api.
Related ONTAP commands
event notification destination modify -
event notification modify
Learn more
name |
string |
path |
True |
Destination name |
Request Body
| Name | Type | Description |
_links |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
Example request
"href": "/api/resourcelink"
"certificate": {
"ca": "VeriSign",
"serial_number": 1234567890
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
Status: 200, Ok
_links |
certificate |
destination |
string |
Event destination |
filters |
array[filters] |
"certificate": {
"ca": "VeriSign",
"filters": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The destination name provided cannot be empty |
983089 |
The destination name provided cannot contain spaces |
983094 |
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen) |
983104 |
The syslog destination provided is invalid |
983116 |
The number of notifications has reached maximum capacity |
983117 |
The number of destinations has reached maximum capacity |
983129 |
The rest-api destination must contain a valid scheme, such as http// or https// |
983130 |
The rest-api destination provided contains an invalid URL |
983131 |
The rest-api destination provided contains an invalid IPv6 URL |
983142 |
The security certificate provided does not exist |
983143 |
The private security key provided does not exist |
983144 |
The security certificate information provided is incomplete. Provide the certificate and serial number |
983145 |
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information |
983150 |
The type of an existing destination cannot be changed |
983151 |
A property provided cannot be configured on the requested destination type |
983152 |
Default destinations cannot be modified or removed |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
_links |
name |
string |
ems_destination
_links |
certificate |
destination |
string |
Event destination |
filters |
array[filters] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
