Update an event filter
PATCH /support/ems/filters/{name}
Updates an event filter.
Recommended optional properties
new_name- New string that uniquely identifies a filter. -
rules- New list of criteria used to match the filter with an event. The existing list is discarded.
Related ONTAP commands
event filter create -
event filter delete -
event filter rename -
event filter rule add -
event filter rule delete -
event filter rule reorder
Learn more
name |
string |
path |
True |
Filter name |
new_name |
string |
query |
False |
New filter name for renames. Valid in PATCH. |
Request Body
| Name | Type | Description |
_links |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
Example request
"href": "/api/resourcelink"
"name": "snmp-traphost",
"rules": [
"index": 1,
"message_criteria": {
"related": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The filter name provided is empty |
983089 |
The filter name provided cannot contain spaces |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983094 |
The filter name provided is invalid. The filter name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or (underscore). The allowed special characters are (underscore) and -(hyphen) |
983095 |
The rule index provided is invalid for the filter provided |
983101 |
No event is matched by the rule provided |
983113 |
Default filters cannot be modified or removed |
983114 |
The maximum number of filters is reached |
983115 |
The maximum number of filter rules is reached |
983126 |
A rule requires at least one of name_pattern, severities or snmp-trap-types to be defined |
983127 |
A property cannot contain a combination of the wildcard characters and other values |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severity levels provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
_links
related |
message_criteria
Matching message definitions for the filter. A property must be specified.
_links |
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
rules
Rule for an event filter
_links |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
ems_filter
_links |
name |
string |
Filter name |
rules |
array[rules] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
