Update EMS configuration
PATCH /support/ems
Updates the EMS configuration.
Related ONTAP commands
event config modify
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
mail_from |
string |
Mail from |
mail_server |
string |
Mail server (SMTP) |
proxy_password |
string |
Password for HTTP/HTTPS proxy |
proxy_url |
string |
HTTP/HTTPS proxy URL |
proxy_user |
string |
User name for HTTP/HTTPS proxy |
Example request
"href": "/api/resourcelink"
"mail_from": "administrator@mycompany.com",
"mail_server": "mail@mycompany.com",
"proxy_password": "password",
"proxy_url": "https://proxyserver.mycompany.com",
"proxy_user": "proxy_user"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983123 |
The validation of the mail server provided failed |
983136 |
The proxy URL cannot contain a username or password |
983137 |
The proxy URLprovided is invalid |
983139 |
The IPv6 proxy URL provided is invalid |
983140 |
The proxy URL provided contains an invalid scheme. Supported schemes are 'http' or 'https' |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ems_config
_links |
mail_from |
string |
Mail from |
mail_server |
string |
proxy_password |
string |
proxy_url |
string |
proxy_user |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
