Update cluster-wide SNMP configuration
PATCH /support/snmp
Updates the cluster wide SNMP configuration, such as enabling or disabling SNMP and enabling or disabling authentication traps.
Related ONTAP commands
options snmp.enable -
system snmp authtrap
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
auth_traps_enabled |
boolean |
Specifies whether to enable or disable SNMP authentication traps. |
enabled |
boolean |
Specifies whether to enable or disable SNMP. |
Example request
"href": "/api/resourcelink"
"auth_traps_enabled": 1,
"enabled": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1179738 |
Cluster identification not available for modification since a cluster has not been created. |
1179739 |
Cluster identification modification is not available in maintenance mode or other boot modes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
snmp
Cluster-wide SNMP configuration.
_links |
boolean |
enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
