Install one or more feature licenses
POST /cluster/licensing/licenses
Installs one or more feature licenses.
Required properties
keys- Array containing a list of NLF or 26-character license keys.
Related ONTAP commands
system license add
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
keys |
array[string] |
licenses |
array[licenses] |
Installed licenses of the package. |
name |
string |
Name of the license. |
scope |
string |
Scope of the license. |
state |
string |
Summary state of package based on all installed licenses. |
Example request
"href": "/api/resourcelink"
"keys": [
"AMEPOSOIKLKGEEEEDGNDEKSJDE"
"licenses": [
"capacity": {
"maximum_size": 0,
"used_size": 0
"compliance": {
"state": "compliant"
"expiry_time": "2019-03-02 19:00:00 UTC",
"owner": "cluster1",
"serial_number": "123456789",
"start_time": "2019-02-02 19:00:00 UTC"
"name": "NFS",
"scope": "string",
Status: 201, Created
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"records": [
"keys": [
"licenses": [
"capacity": {
"maximum_size": 0,
"used_size": 0
"compliance": {
"name": "NFS",
"scope": "string",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1115117 |
Generic licensing error |
1115122 |
No cluster serial number found |
1115124 |
No node serial number found |
1115130 |
No license code was provided |
1115131 |
Installation of the license failed |
1115132 |
License already exists on system |
1115134 |
Serial number does not belong to node |
1115141 |
License data is invalid |
1115142 |
License signature is invalid |
1115143 |
Internal error applying the requested license |
1115152 |
License does not apply to the platform |
1115154 |
Unable to retrieve cluster ID |
1115155 |
Invalid cluster ID found |
1115159 |
License is not in an acceptable format |
1115160 |
License has already expired |
1115164 |
Minimum ONTAP version requirements not met |
1115179 |
FlexCache is not supported on this system |
1115180 |
FlexCache is not supported on cloud systems |
1115407 |
Capacity pool licenses cannot be installed directly |
1115427 |
License is incompatible with capacity pools licensing mode |
66846818 |
Failed to interpret FlexCache license information |
66846821 |
66846822 |
Invalid FlexCache capacity information provided |
655294464 |
Failed to extract license contents |
655294465 |
License key is invalid |
655294466 |
Serial number is invalid |
655294467 |
Version number is invalid |
655294468 |
Expired license |
655294469 |
655294470 |
License does not apply to the product |
errors |
array[error] |
Example error
"errors": [
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
capacity
maximum_size |
integer |
Licensed capacity size (in bytes) that can be used. |
used_size |
integer |
Capacity that is currently used (in bytes). |
compliance
state |
string |
Compliance state of the license. |
licenses
active |
boolean |
A flag indicating whether the license is currently being enforced. |
capacity |
compliance |
evaluation |
boolean |
A flag indicating whether the license is in evaluation mode. |
expiry_time |
string |
Date and time when the license expires. |
owner |
string |
Cluster, node or license manager that owns the license. |
serial_number |
string |
Serial number of the license. |
start_time |
string |
Date and time when the license starts. |
license_package
_links |
keys |
array[string] |
licenses |
array[licenses] |
name |
string |
scope |
string |
state |
string |
_links
next |
self |
records
_links |
keys |
array[string] |
licenses |
array[licenses] |
name |
string |
scope |
string |
state |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
