Create a schedule
POST /cluster/schedules
Creates a schedule.
Required Fields
name - Name of the job schedule. You must provide a minutes field for a cron schedule and an interval field for an interval schedule. Do not provide both a cron field and an interval field.
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
cluster |
The cluster that owns the schedule. Defaults to the local cluster. |
cron |
Details for schedules of type cron. |
interval |
string |
An ISO-8601 duration formatted string. |
name |
string |
Schedule name. Required in the URL or POST body. |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
Example request
"href": "/api/resourcelink"
"cluster": {
"name": "cluster1",
"cron": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"interval": "P1DT2H3M4S",
"name": "string",
"type": "string",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
458788 |
The schedule specified is not a valid schedule. |
459760 |
459763 |
Schedule cannot be created locally using the remote cluster name as the owner. |
459764 |
Cannot create a schedule with the same name as an existing schedule from the MetroCluster partner cluster but of a different schedule type. |
460783 |
As this is a MetroCluster configuration and the local cluster is waiting for switchback, changes to non-system schedules are not allowed. |
460784 |
An error occurred creating the remote cluster version of this schedule. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
name |
string |
Cluster name |
uuid |
string |
Cluster UUID |
cron
days |
array[integer] |
The days of the month the schedule runs. Leave empty for all. |
hours |
array[integer] |
The hours of the day the schedule runs. Leave empty for all. |
minutes |
array[integer] |
The minutes the schedule runs. Required on POST for a cron schedule. |
months |
array[integer] |
The months of the year the schedule runs. Leave empty for all. |
weekdays |
array[integer] |
The weekdays the schedule runs. Leave empty for all. |
schedule
Complete schedule information
_links |
cluster |
cron |
interval |
string |
name |
string |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
