Download a software or firmware package
POST /cluster/software/download
Downloads a software package from the server.
Required properties
url- URL location of the software package
Recommended optional parameters
username- Username of HTTPS/FTP server -
password- Password of HTTPS/FTP server
Related ONTAP commands
cluster image package get
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
Request Body
| Name | Type | Description |
password |
string |
Password for download |
url |
string |
HTTP or FTP URL of the package through a server |
username |
string |
Username for download |
Example request
"password": "admin_password",
"url": "http://server/package",
"username": "admin"
Status: 202, Accepted
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
software_package_download
password |
string |
url |
string |
username |
string |
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
