Create an LDAP configuration for an SVM
POST /name-services/ldap
Creates an LDAP configuration for an SVM.
Important notes
Each SVM can have one LDAP configuration.
The LDAP servers and Active Directory domain are mutually exclusive fields. These fields cannot be empty. At any point in time, either the LDAP servers or Active Directory domain must be populated.
LDAP configuration with Active Directory domain cannot be created on an admin SVM.
IPv6 must be enabled if IPv6 family addresses are specified.
The following parameters are optional:
preferred AD servers
schema
port
min_bind_level
bind_password
base_scope
use_start_tls
session_security
Configuring more than one LDAP server is recommended to avoid a single point of failure. Both FQDNs and IP addresses are supported for the "servers" field. The Acitve Directory domain or LDAP servers are validated as part of this operation.
LDAP validation fails in the following scenarios:
The server does not have LDAP installed.
The server or Active Directory domain is invalid.
The server or Active Directory domain is unreachable.
Learn more
return_records  |
boolean  |
query  |
False  |
The default is false. If set to true, the records are returned.  |
Request Body
| Name | Type | Description |
_links  |
ad_domain  |
string  |
This parameter specifies the name of the Active Directory domain
used to discover LDAP servers for use by this client.
This is mutually exclusive with   |
base_dn  |
string  |
Specifies the default base DN for all searches.  |
base_scope  |
string  |
Specifies the default search scope for LDAP queries:
bind_dn  |
string  |
Specifies the user that binds to the LDAP servers.  |
bind_password  |
string  |
Specifies the bind password for the LDAP servers.  |
min_bind_level  |
string  |
The minimum bind authentication level. Possible values are:
port  |
integer  |
The port used to connect to the LDAP Servers.  |
preferred_ad_servers  |
array[string]  |
schema  |
string  |
The name of the schema template used by the SVM.
servers  |
array[string]  |
session_security  |
string  |
Specifies the level of security to be used for LDAP communications:
svm  |
use_start_tls  |
boolean  |
Specifies whether or not to use Start TLS over LDAP connections.  |
Example request
      "href": "/api/resourcelink"
  "ad_domain": "string",
  "base_dn": "string",
  "base_scope": "string",
  "bind_dn": "string",
  "bind_password": "string",
  "min_bind_level": "string",
  "port": 389,
  "preferred_ad_servers": [
    "string"
  "schema": "string",
  "servers": [
    "string"
  "session_security": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
_links  |
num_records  |
integer  |
Number of LDAP records.  |
records  |
array[ldap_service]  |
    "next": {
  "records": [
      "port": 389,
        "string"
      "schema": "string",
      "servers": [
        "string"
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262186  |
LDAP Servers cannot be used with Active Directory domain and/or preferred Acti Directory servers  |
2621488  |
Invalid SVM context  |
2621706  |
The specified SVM UUID is incorrect for the specified SVM name  |
4915203  |
The specified LDAP schema does not exist  |
4915207  |
The specified LDAP servers or preferred Active Directory servers contain duplicate server entries  |
4915229  |
DNS resolution failed due to an internal error. Contact technical support if this issue persists  |
4915231  |
DNS resolution failed for one or more of the specified LDAP servers. Verify that a valid DNS server is configured  |
23724132  |
DNS resolution failed for all the specified LDAP servers. Verify that a valid DNS server is configured  |
4915234  |
The specified LDAP server or preferred Active Directory server is not supported because it is one of the following: multicast, loopback, 0.0.0.0, or broadcast  |
4915248  |
LDAP servers cannot be empty or "-". Specified Active Directory domain is invalid because it is empty or "-" or it contains either the special characters or "-" at the start or end of the domain)  |
4915251  |
STARTTLS and LDAPS cannot be used together  |
4915257  |
The LDAP configuration is invalid. Verify that bind-dn and bind password are correct  |
4915258  |
The LDAP configuration is invalid. Verify that the Active Directory domain or servers are reachable and that the network configuration is correct  |
4915259  |
LDAP configurations with Active Directory domains are not supported on admin SVM.  |
13434916  |
The SVM is in the process of being created. Wait a few minutes, and then try the command again.  |
23724130  |
Cannot use an IPv6 name server address because there are no IPv6 LIFs  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
ldap_service
_links  |
ad_domain  |
string  |
base_dn  |
string  |
base_scope  |
string  |
bind_dn  |
string  |
bind_password  |
string  |
min_bind_level  |
string  |
port  |
integer  |
array[string]  |
schema  |
string  |
servers  |
array[string]  |
session_security  |
string  |
svm  |
use_start_tls  |
boolean  |
_links
next  |
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
