Create a new VLAN or LAG
POST /network/ethernet/ports
Creates a new VLAN (such as node1:e0a-100) or LAG (ifgrp, such as node2:a0a).
Required properties
node- Node the port will be created on. -
broadcast_domain- Broadcast domain the port is associated with. -
type- Defines if a VLAN or LAG will be created:-
VLAN
vlan.base_port- Physical port or LAG the VLAN will be created on. -
vlan.tag- Tag used to identify VLAN on the base port.
LAG
lag.mode- Policy for the LAG that will be created. -
lag.distribution_policy- Indicates how the packets are distributed between ports. -
lag.member_ports- Set of ports the LAG consists of.
Related ONTAP commands
network port ifgrp create -
network port vlan create
Learn more
return_records  |
boolean  |
query  |
False  |
The default is false. If set to true, the records are returned.  |
Request Body
| Name | Type | Description |
_links  |
broadcast_domain  |
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input.  |
enabled  |
boolean  |
lag  |
mac_address  |
string  |
mtu  |
integer  |
MTU of the port in bytes. Set by broadcast domain.  |
name  |
string  |
Portname, such as e0a, e1b-100 (VLAN on ethernet), a0c (LAG/ifgrp), a0d-200 (vlan on LAG/ifgrp)  |
node  |
speed  |
integer  |
Link speed in Mbps  |
state  |
string  |
Operational state of the port.  |
type  |
string  |
Type of physical or virtual port  |
uuid  |
string  |
Port UUID  |
vlan  |
Example request
      "href": "/api/resourcelink"
  "broadcast_domain": {
    "ipspace": {
      "name": "ipspace1"
    "name": "bd1",
  "lag": {
    "active_ports": [
        "name": "e1b",
        "node": {
          "name": "node1"
    "distribution_policy": "string",
    "member_ports": [
        "name": "e1b",
        "node": {
          "name": "node1"
    "mode": "string"
  "mac_address": "01:02:03:04:05:06",
  "mtu": 1500,
  "name": "e1b",
  "node": {
    "name": "node1",
  "speed": 1000,
  "state": "string",
  "type": "string",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vlan": {
    "base_port": {
      "name": "e1b",
      "node": {
        "name": "node1"
    "tag": 100
Status: 201, Created
_links  |
num_records  |
integer  |
records  |
array[port]  |
    "next": {
  "records": [
        "ipspace": {
          "name": "ipspace1"
        "name": "bd1",
      "lag": {
        "active_ports": [
            "name": "e1b",
            "node": {
              "name": "node1"
        "member_ports": [
            "name": "e1b",
            "node": {
              "name": "node1"
        "mode": "string"
      "mtu": 1500,
      "name": "e1b",
      "node": {
        "name": "node1",
      "speed": 1000,
      "state": "string",
      "type": "string",
      "vlan": {
        "base_port": {
          "name": "e1b",
          "node": {
            "name": "node1"
        "tag": 100
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376361  |
Port is already a member of a LAG.  |
1966189  |
Port is the home port or current port of an interface.  |
1967083  |
The specified type is not valid.  |
1967084  |
The specified node UUID is not valid.  |
1967085  |
The specified node name is not valid.  |
1967086  |
Node name and UUID must match if both are provided.  |
1967087  |
The specified broadcast domain UUID is not valid.  |
1967088  |
The specified broadcast domain name does not exist in the specified IPspace.  |
1967089  |
The specified broadcast domain UUID, name, and IPspace name do not match.  |
1967090  |
The specified VLAN base port UUID is not valid.  |
1967091  |
The specified VLAN base port name and node name are not valid.  |
1967092  |
The specified node does not match the node specified for the VLAN base port.  |
1967093  |
The specified VLAN base port UUID, name, and VLAN base port node name do not match.  |
1967094  |
The specified LAG member port UUID is not valid.  |
1967095  |
The specified LAG member port name and node name combination is not valid.  |
1967096  |
The specified node does not match the specified LAG member port node.  |
1967097  |
The specified LAG member ports UUID, name, and node name do not match.  |
1967098  |
VLAN POST operation has failed because admin status could not be set for the specified port.  |
1967099  |
Partial success of the VLAN POST operation. Verify the state of the created VLAN for more information.  |
1967100  |
LAG POST operation failed because admin status could not be set.  |
1967101  |
Partial success of the LAG POST operation. Verify the state of the created LAG for more information.  |
1967102  |
POST operation might have left the configuration in an inconsistent state. Check the configuration.  |
1967148  |
Failure to remove port from broadcast domain.  |
1967149  |
Failure to add port to broadcast domain.  |
1967175  |
VLANs cannot be created on ports in the Cluster IPspace.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ipspace
name  |
string  |
Name of the broadcast domain's IPspace  |
broadcast_domain
_links  |
ipspace  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
uuid  |
string  |
Broadcast domain UUID  |
node
name  |
string  |
Name of node on which the port is located.  |
active_ports
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links  |
name  |
string  |
node  |
uuid  |
string  |
member_ports
_links  |
name  |
string  |
node  |
uuid  |
string  |
lag
active_ports  |
array[active_ports]  |
Active ports of a LAG (ifgrp). (Some member ports may be inactive.)  |
distribution_policy  |
string  |
Policy for mapping flows to ports for outbound packets through a LAG (ifgrp).  |
member_ports  |
array[member_ports]  |
mode  |
string  |
Determines how the ports interact with the switch.  |
node
_links  |
name  |
string  |
uuid  |
string  |
base_port
_links  |
name  |
string  |
node  |
uuid  |
string  |
vlan
base_port  |
Port UUID along with readable names. Either the UUID or both names may be supplied on input.  |
tag  |
integer  |
VLAN ID  |
port
_links  |
broadcast_domain  |
enabled  |
boolean  |
lag  |
mac_address  |
string  |
mtu  |
integer  |
name  |
string  |
node  |
speed  |
integer  |
state  |
string  |
type  |
string  |
uuid  |
string  |
Port UUID  |
vlan  |
_links
next  |
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
