Create a new VLAN or LAG
POST /network/ethernet/ports
Introduced In: 9.6
Creates a new VLAN (such as node1:e0a-100) or LAG (ifgrp, such as node2:a0a).
Required properties
node- Node the port will be created on. -
type- Defines if a VLAN or LAG will be created:-
VLAN
vlan.base_port- Physical port or LAG the VLAN will be created on. -
vlan.tag- Tag used to identify VLAN on the base port.
LAG
lag.mode- Policy for the LAG that will be created. -
lag.distribution_policy- Indicates how the packets are distributed between ports. -
lag.member_ports- Set of ports the LAG consists of.
Optional properties
broadcast_domain- The layer-2 broadcast domain the port is associated with. The port will be placed in a broadcast domain if it is not specified. It may take several minutes for the broadcast domain to be assigned. During that period the port cannot host interfaces.
Related ONTAP commands
network port ifgrp create -
network port vlan create
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
broadcast_domain  |
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input.  |
enabled  |
boolean  |
lag  |
mac_address  |
string  |
mtu  |
integer  |
MTU of the port in bytes. Set by broadcast domain.  |
name  |
string  |
Portname, such as e0a, e1b-100 (VLAN on ethernet), a0c (LAG/ifgrp), a0d-200 (vlan on LAG/ifgrp)  |
node  |
reachable_broadcast_domains  |
array[reachable_broadcast_domains]  |
Reachable broadcast domains.  |
speed  |
integer  |
Link speed in Mbps  |
state  |
string  |
Operational state of the port.  |
type  |
string  |
Type of physical or virtual port  |
uuid  |
string  |
Port UUID  |
vlan  |
Example request
  "broadcast_domain": {
    "ipspace": {
      "name": "ipspace1"
    "name": "bd1",
  "lag": {
    "active_ports": [
        "name": "e1b",
        "node": {
          "name": "node1"
    "distribution_policy": "string",
    "member_ports": [
        "name": "e1b",
        "node": {
          "name": "node1"
    "mode": "string"
  "mac_address": "01:02:03:04:05:06",
  "mtu": "1500",
  "name": "e1b",
  "node": {
    "name": "node1",
  "reachable_broadcast_domains": [
      "ipspace": {
        "name": "ipspace1"
      "name": "bd1",
  "speed": "1000",
  "state": "string",
  "type": "string",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vlan": {
    "base_port": {
      "name": "e1b",
      "node": {
        "name": "node1"
    "tag": "100"
Status: 201, Created
num_records  |
integer  |
records  |
array[port]  |
  "records": [
        "ipspace": {
          "name": "ipspace1"
        "name": "bd1",
      "lag": {
        "active_ports": [
            "name": "e1b",
            "node": {
              "name": "node1"
        "member_ports": [
            "name": "e1b",
            "node": {
              "name": "node1"
        "mode": "string"
      "mtu": "1500",
      "name": "e1b",
      "node": {
        "name": "node1",
          "ipspace": {
            "name": "ipspace1"
          "name": "bd1",
      "speed": "1000",
      "state": "string",
      "type": "string",
      "vlan": {
        "base_port": {
          "name": "e1b",
          "node": {
            "name": "node1"
        "tag": "100"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376361  |
Port is already a member of a LAG.  |
1966189  |
Port is the home port or current port of an interface.  |
1967083  |
The specified type is not valid.  |
1967084  |
The specified node UUID is not valid.  |
1967085  |
The specified node name is not valid.  |
1967086  |
Node name and UUID must match if both are provided.  |
1967087  |
The specified broadcast domain UUID is not valid.  |
1967088  |
The specified broadcast domain name does not exist in the specified IPspace.  |
1967089  |
The specified broadcast domain UUID, name, and IPspace name do not match.  |
1967090  |
The specified VLAN base port UUID is not valid.  |
1967091  |
The specified VLAN base port name and node name are not valid.  |
1967092  |
The specified node does not match the node specified for the VLAN base port.  |
1967093  |
The specified VLAN base port UUID, name, and VLAN base port node name do not match.  |
1967094  |
The specified LAG member port UUID is not valid.  |
1967095  |
The specified LAG member port name and node name combination is not valid.  |
1967096  |
The specified node does not match the specified LAG member port node.  |
1967097  |
The specified LAG member ports UUID, name, and node name do not match.  |
1967098  |
VLAN POST operation has failed because admin status could not be set for the specified port.  |
1967099  |
Partial success of the VLAN POST operation. Verify the state of the created VLAN for more information.  |
1967100  |
LAG POST operation failed because admin status could not be set.  |
1967101  |
Partial success of the LAG POST operation. Verify the state of the created LAG for more information.  |
1967102  |
POST operation might have left the configuration in an inconsistent state. Check the configuration.  |
1967148  |
Failure to remove port from broadcast domain.  |
1967149  |
Failure to add port to broadcast domain.  |
1967175  |
VLANs cannot be created on ports in the Cluster IPspace.  |
href  |
string  |
_links
ipspace
name  |
string  |
Name of the broadcast domain's IPspace  |
broadcast_domain
ipspace  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
uuid  |
string  |
Broadcast domain UUID  |
node
name  |
string  |
Name of node on which the port is located.  |
active_ports
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name  |
string  |
node  |
uuid  |
string  |
member_ports
name  |
string  |
node  |
uuid  |
string  |
lag
active_ports  |
array[active_ports]  |
Active ports of a LAG (ifgrp). (Some member ports may be inactive.)  |
distribution_policy  |
string  |
Policy for mapping flows to ports for outbound packets through a LAG (ifgrp).  |
member_ports  |
array[member_ports]  |
mode  |
string  |
Determines how the ports interact with the switch.  |
throughput
The rate of throughput bytes per second observed at the port object.
read  |
integer  |
Performance metric for read I/O operations.  |
total  |
integer  |
Performance metric aggregated over all types of I/O operations.  |
write  |
integer  |
Peformance metric for write I/O operations.  |
metric
The most recent sample of I/O metrics for the port.
duration  |
string  |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:  |
status  |
string  |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.  |
throughput  |
The rate of throughput bytes per second observed at the port object.  |
timestamp  |
string  |
The timestamp of the performance data.  |
node
name  |
string  |
uuid  |
string  |
ipspace  |
name  |
string  |
uuid  |
string  |
receive_raw
Packet receive counters for the Ethernet port.
discards  |
integer  |
Total number of discarded packets.  |
errors  |
integer  |
Number of packet errors.  |
packets  |
integer  |
Total packet count.  |
transmit_raw
Packet transmit counters for the Ethernet port.
discards  |
integer  |
errors  |
integer  |
packets  |
integer  |
device
Device-related counters for the port object. These counters are applicable at the lowest layer of the networking stack. These values can be used to calculate both transmit and receive packet and error rates by comparing two samples taken at different times and calculating the increase in counter value divided by the elapsed time between the two samples.
link_down_count_raw  |
integer  |
The number of link state changes from up to down seen on the device.  |
timestamp  |
string  |
The timestamp when the device specific counters were collected.  |
throughput_raw
Throughput bytes observed at the port object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read  |
integer  |
total  |
integer  |
write  |
integer  |
statistics
The real time I/O statistics for the port.
status  |
string  |
throughput_raw  |
Throughput bytes observed at the port object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.  |
timestamp  |
string  |
The timestamp of the throughput_raw performance data.  |
base_port
name  |
string  |
node  |
uuid  |
string  |
vlan
base_port  |
Port UUID along with readable names. Either the UUID or both names may be supplied on input.  |
tag  |
integer  |
VLAN ID  |
port
broadcast_domain  |
enabled  |
boolean  |
lag  |
mac_address  |
string  |
mtu  |
integer  |
name  |
string  |
node  |
speed  |
integer  |
state  |
string  |
type  |
string  |
uuid  |
string  |
Port UUID  |
vlan  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
