REST API reference
Create a new BGP peer group for VIP
POST /network/ip/bgp/peer-groups
Creates a new BGP peer group for VIP. Multipath-routing is turned on cluster-wide automatically if the peer group being created results in multiple paths being available for an existing or future VIP interface.
Required properties
  • name - Name of the peer-group to create.
  • ipspace.name or ipspace.uuid
    • Required with local.interface.name to identify a local interface
    • Optional when local.interface.uuid is specified
  • local.interface.uuid or local.interface.name
    • Required when specifying an existing local interface.
  • local.interface.name, local.ip and local.port
    • Required to create a new local interface.
  • peer.address - IP address of the peer router
  • network bgp peer-group create
return_records
boolean
query
False
Request Body
Name Type Description
ipspace
ipspace
Either the UUID or name is supplied on input.
local
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
name
string
Name of the peer group
peer
peer
Information describing the router to peer with
state
string
State of the peer group
uuid
string
UUID of the peer group
Example request
  "ipspace": {
        "href": "/api/resourcelink"
    "name": "exchange",
  "local": {
    "interface": {
      "ip": {
        "address": "10.10.10.7"
      "name": "lif1",
    "ip": {
      "address": "10.10.10.7",
      "netmask": "24"
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "bgpv4peer",
  "peer": {
  "state": "string",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1376963
Duplicate IP address is specified.
1966133
Netmask and address pair result in a network address.
1966267
IPv6 addresses must have a prefix length of 64.
1966269
IPv4 addresses must have a netmask length between 1 and 32.
1967082
IPspace name and UUID must match if both are given.
1967155
The specified local.port.name does not match the location.port.name for the specified local.interface.
1967156
The specified local.port.node.name does not match the location.port.node.name for the specified local.interface.
1967157
The specified local.port.uuid does not match the location.port.uuid for the specified local.interface.
1967158
The specified local.interface.name does not exist in the associated IPspace. local.ip.address and local.ip.netmask are required to create a new LIF.
1967159
local.interface does not support management-bgp service.
1967160
The specified local.interface.name does not match the specified interface name of local.interface.uuid.
1967161
The specified local.interface.uuid does not exist in the specified IPspace.
1967162
Either local.interface or local.ip and local.port are required to specify a local LIF.
1967163
The specified local.port.name does not match the specified port name of local.port.uuid.
1967164
The specified local.port.node.name does not match the specified node name of local.port.uuid.
1967165
The specified local.port does not exist.
1967166
ipspace.uuid or ipspace.name must be provided with local.interface.name together to identify a LIF.
1967167
Internal error. Failed to update BGP configuration for node. Retry the command, if necessary.
1967168
Internal error. Failed to create a VIP port for IPspace on node. Retry the command, if necessary.
1967169
Internal error. BGP configuration changed during the operation. Retry the command, if necessary.
1967170
Internal error. VIP port configuration changed during the operation. Retry the command, if necessary.
1967171
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary.
1967172
Peer group could not be updated because IPspace does not exist. Retry the command, if necessary.
1967173
The specified local.ip.address does not match the address for the specified local.interface.
1967174
The specified local.ip.netmask does not match the netmask for the specified local.interface.
1967176
The specified local.interface.name does not exist in the associated IPspace. local.port.name, local.port.node.name, or local.port.uuid is required to create a new LIF.
1967177
Internal error. Failed to access the local interface. Retry the command, if necessary.
1967178
The IPv6 address specified with local.ip.address is not supported because it is link-local, multicast, v4-compatible, v4-mapped, loopback or "::".
1967179
The IPv4 address specified with local.ip.address is not supported because it is multicast, loopback or 0.0.0.0.
53281985
Internal error. Failed to update BGP peer group because BGP LIF moved during the operation. Wait a few minutes and try the command again.
53282006
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address.
53282007
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family.
53282018
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
_links
_links
ip
ip
IP information
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
ip
IP information to create a new interface.
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.
node
name
string
Name of node on which the port is located.
port
_links
_links
name
string
node
node
uuid
string
local
interface
interface
ip
ip
port
port
peer
address
string
Peer router address
asn
integer
Autonomous system number of peer
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace
ipspace
local
local
name
string
peer
peer
state
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
