Creates an fpolicy policy configuration for the specified svm to create an fpolicy policy, you must specify the policy scope and the fpolicy events to be monitored
an fpolicy engine is an optional field whose default value is set to native a native engine can be used to simply block the file access based on the file extensions specified in the policy scope
to enable a policy, the policy priority must be specified if the priority is not specified, the policy is created but it is not enabled
the "mandatory" field, if set to true, blocks the file access when the primary or secondary fpolicy servers are down # required properties
svmuuid- existing svm in which to create the fpolicy policy -
events- name of the events to monitior -
name- name of the fpolicy policy -
scope- scope of the policy can be limited to exports, volumes, shares or file extensions -
priority- priority of the policy (ranging from 1 to 10) # default property values -
mandatory- true -
engine- native # related ontap commands -
fpolicy policy scope create -
fpolicy policy create -
fpolicy enable# learn more -
doc /protocols/fpolicy/{svmuuid}/policies](#docs-nas-protocols_fpolicy_{svmuuid}_policies)
POST /protocols/fpolicy/{svm.uuid}/policies
Creates an FPolicy policy configuration for the specified SVM. To create an FPolicy policy, you must specify the policy scope and the FPolicy events to be monitored.
Important notes:
A single policy can monitor multiple events.
An FPolicy engine is an optional field whose default value is set to native. A native engine can be used to simply block the file access based on the file extensions specified in the policy scope.
To enable a policy, the policy priority must be specified. If the priority is not specified, the policy is created but it is not enabled.
The "mandatory" field, if set to true, blocks the file access when the primary or secondary FPolicy servers are down.
Required properties
svm.uuid- Existing SVM in which to create the FPolicy policy. -
events- Name of the events to monitior. -
name- Name of the FPolicy policy. -
scope- Scope of the policy. Can be limited to exports, volumes, shares or file extensions. -
priority- Priority of the policy (ranging from 1 to 10).
Default property values
mandatory- true -
engine- native
Related ONTAP commands
fpolicy enable
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
engine |
FPolicy external engine |
events |
array[fpolicy_event_reference] |
mandatory |
boolean |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances. |
name |
string |
Specifies the name of the policy. |
priority |
integer |
Specifies the priority that is assigned to this policy. |
scope |
Example request
"enabled": null,
"engine": {
"href": "/api/resourcelink"
"name": "string"
"events": [
"event_nfs_close",
"event_open"
"name": "fp_policy_1",
"scope": {
"exclude_export_policies": [
"string"
"exclude_extension": [
"string"
"exclude_shares": [
"string"
"exclude_volumes": [
"vol1",
"vol_svm1",
"include_export_policies": [
"string"
"include_extension": [
"string"
"include_shares": [
"sh1",
"share_cifs"
"include_volumes": [
"vol1",
"vol_svm1"
Status: 201, Created
_links |
num_records |
integer |
Number of Records |
records |
array[fpolicy_policy] |
"next": {
"records": [
"enabled": null,
"engine": {
"name": "string"
"events": [
"event_nfs_close",
"event_open"
"scope": {
"string"
"string"
"exclude_shares": [
"string"
"vol1",
"vol_svm1",
"string"
"string"
"include_shares": [
"sh1",
"share_cifs"
"vol1",
"vol_svm1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9765027 |
FPolicy creation is successful but it cannot be enabled as the priority is already in use by another policy |
9764898 |
An FPolicy policy cannot be created without defining its scope |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
fpolicy_engine_reference
_links |
name |
string |
The name of the FPolicy external engine. |
FPolicy events
_links |
name |
string |
scope
exclude_export_policies |
array[string] |
exclude_extension |
array[string] |
exclude_shares |
array[string] |
exclude_volumes |
array[string] |
include_export_policies |
array[string] |
include_extension |
array[string] |
include_shares |
array[string] |
include_volumes |
array[string] |
fpolicy_policy
engine |
events |
mandatory |
boolean |
name |
string |
priority |
integer |
scope |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
