Create an export policy
POST /protocols/nfs/export-policies
Creates an export policy. An SVM can have any number of export policies to define rules for which clients can access data exported by the SVM. A policy with no rules prohibits access.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create an export policy. -
name- Name of the export policy.
Recommended optional properties
rules- Rule(s) of an export policy. Used to create the export rule and populate the export policy with export rules in a single request.
Related ONTAP commands
vserver export-policy create -
vserver export-policy rule create
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
id |
integer |
Export Policy ID |
name |
string |
Export Policy Name |
rules |
array[export_rule] |
Rules of the Export Policy. |
svm |
Example request
"href": "/api/resourcelink"
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: 201, Created
_links |
num_records |
integer |
The number of export policy records |
records |
array[export_policy] |
"next": {
"records": [
"id": 0,
"name": "string",
"rules": [
"clients": [
"index": 0,
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703952 |
Invalid ruleset name provided. No spaces allowed in a ruleset name |
1703954 |
Export policy does not exist |
1704049 |
Invalid clientmatch: clientmatch lists require an effective cluster version of Data ONTAP 9.0 or later. Upgrade all nodes to Data ONTAP 9.0 or above to use features that operate on lists of clientmatch strings in export-policy rules |
1704055 |
Export policies are only supported for data Vservers |
3277000 |
Upgrade all nodes to Data ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules |
3277083 |
User ID is not valid. Enter a value for User ID from 0 to 4294967295 |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_client
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rule
_links |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
clients |
array[export_client] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
export_policy
_links |
id |
integer |
Export Policy ID |
name |
string |
rules |
svm |
export_client
match |
string |
_links
next |
self |
export_client
match |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
