Create S3 server, users, and buckets configurations
POST /protocols/s3/services
Creates an S3 server, users, and buckets configurations.
Important notes
Each SVM can have one S3 server configuration.
One or more buckets and users can also be created using this end-point.
If creating a user configuration fails, buckets are not created either and already created users are not saved.
If creating a bucket configuration fails, all buckets already created are saved with no new buckets created.
Required properties
svm.uuid- Existing SVM in which to create an S3 server configuration.
Recommended optional properties
enabled- Specifies the state of the server created. -
comment- Any information related to the server created.
Default property values
comment- "" -
enabled- true
Related ONTAP commands
vserver object-store-server create -
vserver object-store-server bucket create -
vserver object-store-server user create
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
buckets |
array[s3_bucket] |
comment |
string |
Can contain any additional information about the server being created or modified. |
enabled |
boolean |
Specifies whether the S3 server being created or modified should be up or down. |
name |
string |
Specifies the name of the S3 server. A server name can contain 0 to 15 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-". |
svm |
users |
array[s3_user] |
Example request
"href": "/api/resourcelink"
"buckets": [
"aggregates": [
"name": "aggr1",
"comment": "S3 bucket.",
"constituents_per_aggregate": 4,
"logical_used_size": 0,
"name": "bucket-1",
"size": 1677721600,
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"volume": {
"name": "volume1",
"comment": "S3 server",
"name": "Server-1",
"svm": {
"name": "svm1",
"users": [
"access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
"comment": "S3 user",
"name": "user-1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of Records |
records |
array[records] |
"records": [
"next": {
"job": {
"uuid": "string"
"users": [
"next": {
"name": "user-1",
"secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
92405789 |
The specified object server name contains invalid characters or not a fully qualified domain name. Valid characters for an object store server name are 0-9, A-Z, a-z, ".", and "-". |
92405790 |
Object store server names must have between 1 and 15 characters. |
92405839 |
Creating an object store server requires an effective cluster version of data ONTAP 9.7.0 or later. Upgrade all the nodes to 9.7.0 or later and try the operation again. |
92405853 |
Failed to create the object store server because Cloud Volumes ONTAP does not support object store servers. |
92405863 |
An error occurs when creating an S3 user or bucket. The reason for failure is detailed in the error message. Follow the error codes specified for the user or bucket endpoints to see details for the failure. |
92405884 |
An object store server can only be created on a data SVM. An object store server can also be created on a system SVM on a mixed platform cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
_links |
name |
string |
The name of the volume. |
uuid |
string |
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
aggregates |
array[aggregates] |
A list of aggregates for FlexGroup volume constituents where the bucket is hosted. If this option is not specified, the bucket is auto-provisioned as a FlexGroup volume. |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
constituents_per_aggregate |
integer |
Specifies the number of constituents or FlexVol volumes per aggregate. A FlexGroup volume consisting of all such constituents across all specified aggregates is created. This option is used along with the aggregates option and cannot be used independently. |
encryption |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
svm |
uuid |
string |
Specifies the unique identifier of the bucket. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
s3_user
This is a container of S3 users.
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
s3_service
Specifies the S3 server configuration.
_links |
buckets |
array[s3_bucket] |
comment |
string |
enabled |
boolean |
name |
string |
svm |
users |
array[s3_user] |
collection_links
next |
self |
job_link
_links |
uuid |
string |
s3_service_user_post_response
_links |
access_key |
string |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
records
_links |
job |
users |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
