Add initiators to an initiator group
POST /protocols/san/igroups/{igroup.uuid}/initiators
Adds one or more initiators to an initiator group.
Required properties
nameorrecords.name- Initiator name(s) to add to the initiator group.
Related ONTAP commands
lun igroup add
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
Request Body
| Name | Type | Description |
_links |
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consist of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
records |
array[records] |
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Valid in POST only and not allowed when the |
Example request
"href": "/api/resourcelink"
"igroup": {
"name": "iqn.1998-01.com.corp.iscsi:name1",
"records": [
"igroup": {
Status: 201, Created
_links |
num_records |
integer |
Number of records. |
records |
array[igroup_initiator] |
"next": {
"records": [
"igroup": {
"records": [
"igroup": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254193 |
Adding an initiator would cause the initiator to be mapped to the same LUN more than once. |
1254324 |
Adding an initiator would cause the initiator to have the same logical unit identifier for multiple LUN maps. |
5373969 |
A supplied initiator name looks like an iSCSI IQN initiator, but the portions after the prefix are missing. |
5373971 |
A supplied initiator name looks like an iSCSI IQN initiator, but the date portion is invalid. |
5373972 |
A supplied initiator name looks like an iSCSI IQN initiator, but the naming authority portion is invalid. |
5373977 |
A supplied initiator name looks like an iSCSI EUI initiator, but the length is invalid. |
5373978 |
A supplied initiator name looks like an iSCSI EUI initiator, but the format is invalid. |
5373992 |
A supplied initiator name was too long to be valid. |
5373993 |
A supplied initiator name did not match any valid format. |
5374033 |
Initiators must be supplied. |
5374035 |
A supplied initiator is already in the initiator group. |
5374038 |
An invalid Fibre Channel WWPN was supplied. |
5374039 |
An invalid iSCSI initiator name was supplied. |
5374734 |
An initiator is already in another initiator group with a conflicting operating system type. |
5374852 |
The initiator group specified in the URI does not exist. |
5374853 |
You can add initiators to an initiator group using the |
5374854 |
Only |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
igroup
_links |
uuid |
string |
records
_links |
igroup |
name |
string |
igroup_initiator
_links |
igroup |
name |
string |
records |
array[records] |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
