Configure a data SVM as a proxy
POST /security/authentication/cluster/ad-proxy
Configures a data SVM as a proxy for Active Directory-based authentication for cluster user accounts.
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
Status: 201, Created
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
_links |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
