Update the user account password
POST /security/authentication/password
Updates the password for a user account.
Required parameters
name- User account name. -
password- New password for the user account.
Optional parameters
owner.nameorowner.uuid- Name or UUID of the SVM for an SVM-scoped user account.
Related ONTAP commands
security login password
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
name |
string |
The user account name whose password is being modified. |
owner |
Owner name and UUID that uniquely identifies the user account. This field is optional and valid only when a cluster administrator is executing the API to uniquely identify the account whose password is being modified. The "owner" field is not required to be specified for SVM user accounts trying to modify their password. |
password |
string |
The password string |
Example request
"name": "string",
"owner": {
"href": "/api/resourcelink"
"name": "svm1",
"password": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
7077918 |
The password cannot contain the username. |
7077919 |
The minimum length for new password does not meet the policy. |
7077920 |
The new password must have both letters and numbers. |
7077921 |
The minimum number of special characters required do not meet the policy. |
7077924 |
The new password must be different than last N passwords. |
7077925 |
The new password must be different to the old password. |
7077940 |
The password exceeds maximum supported length. |
7077941 |
Defined password composition exceeds the maximum password length of 128 characters. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
owner
_links |
name |
string |
The name of the SVM. |
uuid |
string |
account_password
The password object
name |
string |
owner |
password |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
