Create or install security certificates
POST /security/certificates
Creates or installs a certificate.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create or install the certificate. -
common_name- Common name of the certificate. Required when creating a certificate. -
type- Type of certificate. -
public_certificate- Public key certificate in PEM format. Required when installing a certificate. -
private_key- Private key certificate in PEM format. Required when installing a CA-signed certificate.
Recommended optional properties
expiry_time- Certificate expiration time. Specifying an expiration time is recommended when creating a certificate. -
key_size- Key size of the certificate in bits. Specifying a strong key size is recommended when creating a certificate.
Default property values
If not specified in POST, the following default property values are assigned:
key_size- 2048 -
expiry_time- P365DT -
hash_function- sha256
Related ONTAP commands
security certificate create -
security certificate install
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
ca |
string |
Certificate authority |
common_name |
string |
FQDN or custom common name. Provide on POST when creating a self-signed certificate. |
expiry_time |
string |
Certificate expiration time. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years. |
hash_function |
string |
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST. |
intermediate_certificates |
array[string] |
Chain of intermediate Certificates in PEM format. Only valid in POST when installing a certificate. |
key_size |
integer |
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate. Key size of 512 is not allowed on POST. |
private_key |
string |
Private key Certificate in PEM format. Only valid for create when installing a CA-signed certificate. This is not audited. |
public_certificate |
string |
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
serial_number |
string |
Serial number of certificate. |
svm |
type |
string |
Type of Certificate. The following types are supported:
uuid |
string |
Unique ID that identifies a certificate. |
Example request
"href": "/api/resourcelink"
"ca": "string",
"common_name": "test.domain.com",
"expiry_time": "string",
"hash_function": "string",
"intermediate_certificates": [
"-----BEGIN CERTIFICATE----- MIIBuzCCAWWgAwIBAgIIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQAwHDENMAsGA1UE AxMEVEVTVDELMAkGA1UEBhMCVVMwHhcNMTgwNjA4MTgwOTAxWhcNMTkwNjA4MTgw OTAxWjAcMQ0wCwYDVQQDEwRURVNUMQswCQYDVQQGEwJVUzBcMA0GCSqGSIb3DQEB AQUAA0sAMEgCQQDaPvbqUJJFJ6NNTyK3Yb+ytSjJ9aa3yUmYTD9uMiP+6ycjxHWB e8u9z6yCHsW03ync+dnhE5c5z8wuDAY0fv15AgMBAAGjgYowgYcwDAYDVR0TBAUw AwEB/zALBgNVHQ8EBAMCAQYwHQYDVR0OBBYEFMJ7Ev/o/3+YNzYh5XNlqqjnw4zm MEsGA1UdIwREMEKAFMJ7Ev/o/3+YNzYh5XNlqqjnw4zmoSCkHjAcMQ0wCwYDVQQD EwRURVNUMQswCQYDVQQGEwJVU4IIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQADQQAv DovYeyGNnknjGI+TVNX6nDbyzf7zUPqnri0KuvObEeybrbPW45sgsnT5dyeE/32U 9Yr6lklnkBtVBDTmLnrC -----END CERTIFICATE-----"
"private_key": "-----BEGIN PRIVATE KEY----- MIIBVAIBADANBgkqhkiG9w0BAQEFAASCAT4wggE6AgEAAkEAu1/a8f3G47cZ6pel Hd3aONMNkGJ8vSCH5QjicuDm92VtVwkAACEjIoZSLYlJvPD+odL+lFzVQSmkneW7 VCGqYQIDAQABAkAcfNpg6GCQxoneLOghvlUrRotNZGvqpUOEAvHK3X7AJhz5SU4V an36qvsAt5ghFMVM2iGvGaXbj0dAd+Jg64pxAiEA32Eh9mPtFSmZhTIUMeGcPmPk qIYCEuP8a/ZLmI9s4TsCIQDWvLQuvjSVfwPhi0TFAb5wqAET8X5LBFqtGX5QlUep EwIgFnqM02Gc4wtLoqa2d4qPkYu13+uUW9hLd4XSd6i/OS8CIQDT3elU+Rt+qIwW u0cFrVvNYSV3HNzDfS9N/IoxTagfewIgPvXADe5c2EWbhCUkhN+ZCf38AKewK9TW lQcDy4L+f14= -----END PRIVATE KEY-----",
"public_certificate": "-----BEGIN CERTIFICATE----- MIIBuzCCAWWgAwIBAgIIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQAwHDENMAsGA1UE AxMEVEVTVDELMAkGA1UEBhMCVVMwHhcNMTgwNjA4MTgwOTAxWhcNMTkwNjA4MTgw OTAxWjAcMQ0wCwYDVQQDEwRURVNUMQswCQYDVQQGEwJVUzBcMA0GCSqGSIb3DQEB AQUAA0sAMEgCQQDaPvbqUJJFJ6NNTyK3Yb+ytSjJ9aa3yUmYTD9uMiP+6ycjxHWB e8u9z6yCHsW03ync+dnhE5c5z8wuDAY0fv15AgMBAAGjgYowgYcwDAYDVR0TBAUw AwEB/zALBgNVHQ8EBAMCAQYwHQYDVR0OBBYEFMJ7Ev/o/3+YNzYh5XNlqqjnw4zm MEsGA1UdIwREMEKAFMJ7Ev/o/3+YNzYh5XNlqqjnw4zmoSCkHjAcMQ0wCwYDVQQD EwRURVNUMQswCQYDVQQGEwJVU4IIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQADQQAv DovYeyGNnknjGI+TVNX6nDbyzf7zUPqnri0KuvObEeybrbPW45sgsnT5dyeE/32U 9Yr6lklnkBtVBDTmLnrC -----END CERTIFICATE-----",
"scope": "string",
"serial_number": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: 201, Created
_links |
num_records |
integer |
Number of records |
records |
array[security_certificate] |
"next": {
"records": [
"ca": "string",
"scope": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735645 |
Cannot specify a value for serial. It is generated automatically. |
3735622 |
The certificate type is not supported. |
3735664 |
The specified key size is not supported in FIPS mode. |
3735665 |
The specified hash function is not supported in FIPS mode. |
3735553 |
Failed to create self-signed Certificate. |
3735646 |
Failed to store the certificates. |
3735693 |
The certificate installation failed as private key was empty. |
3735618 |
Cannot accept private key for server-ca or client-ca. |
52363365 |
Failed to allocate memory. |
52559975 |
Failed to read the certificate due to incorrect formatting. |
52363366 |
Unsupported key type. |
52560123 |
Failed to read the key due to incorrect formatting. |
52559972 |
The certificates start date is later than the current date. |
52559976 |
The certificate and private key do not match. |
52559973 |
The certificate has expired. |
52363366 |
Logic error: use of a dead object. |
3735696 |
Intermediate certificates are not supported with client-ca and server-ca type certificates. |
52559974 |
The certificate is not supported in FIPS mode. |
3735676 |
Cannot continue the installation without a value for the common name. Since the subject field in the certificate is empty, the field "common_name" must have a value to continue with the installation. |
3735558 |
Failed to extract information about Common Name from the certificate. |
3735588 |
The common name (CN) extracted from the certificate is not valid. |
3735632 |
Failed to extract Certificate Authority Information from the certificate. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
ca |
string |
common_name |
string |
expiry_time |
string |
hash_function |
string |
array[string] |
key_size |
integer |
private_key |
string |
string |
scope |
string |
serial_number |
string |
svm |
type |
string |
uuid |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
