Create an IPsec policy
POST /security/ipsec/policies
Creates an IPsec policy.
Related ONTAP commands
security ipsec policy create
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
action |
string |
Action for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
local_endpoint |
Local endpoint for the IPsec policy. |
name |
string |
IPsec policy name. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
secret_key |
string |
Pre-shared key for IKE negotiation. |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
Example request
"action": "string",
"local_endpoint": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24",
"port": "23"
"name": "string",
"protocol": "17",
"remote_endpoint": {
"family": "string",
"netmask": "24",
"port": "23"
"secret_key": "string",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: 201, Created
_links |
error |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": 1,
"records": [
"action": "string",
"local_endpoint": {
"family": "string",
"netmask": "24",
"port": "23"
"name": "string",
"protocol": "17",
"family": "string",
"netmask": "24",
"port": "23"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257099 |
Only one protocol can be specified. |
66257100 |
Only one local port can be specified. |
66257101 |
Only one remote port can be specified. |
66257103 |
IPsec policy with same name already exists in this SVM. |
66257107 |
The specified pre-shared key is not a valid hexadecimal string. |
66257109 |
The specified pre-shared key is not a valid Base64 encoded binary string. |
66257110 |
Failed to a create policy sequencing value. |
66257111 |
The IPsec policy with action ESP TRANSPORT provides packet protection and requires a secret key for authentication. |
66257112 |
The IPsec policy with the action specified does not provide packet protection and the authentication method provided for the policy will be ignored. |
66257113 |
Only one local IP subnet can be specified. |
66257114 |
Only one remote IP subnet can be specified. |
66257115 |
Port ranges containing more than one port are not supported. |
66257117 |
IPsec is not supported on the SVM specified in the policy, IPsec is supported on data SVMs only. |
66257120 |
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask). |
66257121 |
The maximum limit of IPsec Policies has reached for the specified SVM. |
66257125 |
The local_endpoint.address must be specified with local_endpoint.netmask. |
66257126 |
The remote_endpoint.address must be specified with remote_endpoint.netmask. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
local_endpoint
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
remote_endpoint
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
port |
string |
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ipsec_policy
IPsec policy object.
action |
string |
enabled |
boolean |
local_endpoint |
name |
string |
protocol |
string |
remote_endpoint |
secret_key |
string |
svm |
uuid |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
svm
_links |
name |
string |
uuid |
string |
records
action |
string |
enabled |
boolean |
local_endpoint |
name |
string |
protocol |
string |
remote_endpoint |
secret_key |
string |
svm |
uuid |
string |
