Migrate SVM keys between security key managers
POST /security/key-managers/{source.uuid}/migrate
Migrates the keys belonging to an SVM between the cluster's key manager and the SVM's key manager. This operation can run for several minutes.
Required properties
source.uuid- UUID of the source key manager. -
uuid- UUID of the destination key manager.
Related ONTAP commands
security key-manager migrate
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
source.uuid |
string |
path |
True |
Migration source key manager UUID |
Request Body
| Name | Type | Description |
_links |
uuid |
string |
Key manager UUID |
Example request
"href": "/api/resourcelink"
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
info
Migration destination key manager UUID
_links |
uuid |
string |
Key manager UUID |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
