Create a SnapMirror policy
POST /snapmirror/policies
Creates a SnapMirror policy. The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
It takes the following values:
full- indicates that the source SVM configuration is replicated to the destination SVM endpoint. -
exclude_network_config- indicates that the source SVM configuration other than network configuration is replicated to the destination SVM endpoint. -
exclude_network_and_protocol_config- indicates that the source SVM configuration is not replicated to the destination SVM endpoint.
Important note
The properties "identity_preservation", "retention" and "transfer_schedule" are not applicable for "sync" type policies.
The property "sync_common_snapshot_schedule" is not applicable for an "async" type policy.
The property "retention.count" specifies the maximum number of Snapshot copies that are retained on the SnapMirror destination volume.
When the property "retention.label" is specified, the Snapshot copies that have a SnapMirror label matching this property is transferred to the SnapMirror destination.
When the property "retention.creation_schedule" is specified, Snapshot copies are directly created on the SnapMirror destination. The Snapshot copies created have the same content as the latest Snapshot copy already present on the SnapMirror destination.
Required properties
name- Name of the new SnapMirror policy.
Recommended optional properties
svm.nameorsvm.uuid- Name or UUID of the SVM that owns the SnapMirror policy.
Default property values
If not specified in POST, the following default property values are assigned:
type- async -
sync_type- sync (whentypeis sync) -
network_compression_enabled- false -
throttle- 0 -
identity_preservation-exclude_network_and_protocol_config
Related ONTAP commands
snapmirror policy create
Creating a SnapMirror policy of type "sync"
POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "sync"}'
Creating a SnapMirror policy of type "async" with retention values
POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": {"label": ["smcreate"], "count": ["2"], "creation_schedule": ["weekly"]}}'
POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async"}'
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
Request Body
| Name | Type | Description |
_links |
comment |
string |
Comment associated with the policy. |
identity_preservation |
string |
Specifies which configuration of the source SVM is replicated to the destination. This property is applicable only for SVM data protection and async policies. |
name |
string |
network_compression_enabled |
boolean |
Specifies whether network compression is enabled for transfers. This is applicable only to async policies. |
retention |
array[snapmirror_policy_rule] |
Policy on Snapshot copy retention. This is applicable only to async policies. |
scope |
string |
Set to "svm" for policies owned by an SVM, otherwise set to "cluster". |
svm |
sync_common_snapshot_schedule |
Schedule used to create common Snapshot copies for synchronous relationships. |
sync_type |
string |
throttle |
integer |
Throttle in KB/s. Default to unlimited. |
transfer_schedule |
The schedule used to update asynchronous relationships. |
type |
string |
uuid |
string |
Example request
"href": "/api/resourcelink"
"comment": "string",
"identity_preservation": "string",
"name": "Asynchronous",
"retention": [
"count": 7,
"creation_schedule": {
"name": "weekly",
"label": "hourly",
"prefix": "string"
"scope": "string",
"svm": {
"name": "svm1",
"sync_common_snapshot_schedule": {
"name": "weekly",
"sync_type": "string",
"throttle": 0,
"transfer_schedule": {
"name": "weekly",
"type": "string",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303850 |
Invalid input parameter |
13303887 |
Maximum number of allowed retention rules reached |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
SnapMirror policy rule for retention.
count |
integer |
Number of Snapshot copies to be kept for retention. |
creation_schedule |
Schedule used to create Snapshot copies on the destination for long term retention. |
label |
string |
Snapshot copy label |
prefix |
string |
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
transfer_schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapmirror_policy
SnapMirror policy information
_links |
comment |
string |
string |
name |
string |
boolean |
retention |
scope |
string |
svm |
sync_type |
string |
throttle |
integer |
transfer_schedule |
type |
string |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
