Create a SnapMirror relationship
POST /snapmirror/relationships
Creates a SnapMirror relationship. This API can optionally provision the destination endpoint when it does not exist. This API must be executed on the cluster containing the destination endpoint unless the destination endpoint is being provisioned. When the destination endpoint is being provisioned, this API can also be executed from the cluster containing the source endpoint.
Required properties
source.path- Path to the source endpoint of the SnapMirror relationship. -
destination.path- Path to the destination endpoint of the SnapMirror relationship.
Recommended optional properties
policy.nameorpolicy.uuid- Policy governing the SnapMirror relationship. -
state- Set the state to "snapmirrored" to automatically initialize the relationship. -
create_destination.enabled- Enable this property to provision the destination endpoint.
Default property values
If not specified in POST, the following default property values are assigned:
policy.name- Asynchronous -
restore- false -
create_destination.tiering.policy-snapshot_only(whencreate_destination.tiering.supportedis true for FlexVol volume) -
create_destination.tiering.policy-none(whencreate_destination.tiering.supportedis true for FlexGroup volume) -
create_destination.storage_service.enforce_performance-false -
source.ipspace-Default -
destination.ipspace-Default
Related ONTAP commands
snapmirror create -
snapmirror protect
The following examples show how to create FlexVol, FlexGroup and SVM SnapMirror relationships. Note that the source SVM name should be the local name of the peer SVM.
Creating a FlexVol SnapMirror relationship of type XDP.
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}}'
Creating a FlexGroup SnapMirror relationship of type XDP.
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:source_flexgrp"}, "destination": { "path": "test_vserv_dst:dest_flexgrp"}}'
Creating a SVM SnapMirror relationship of type XDP.
POST "/api/snapmirror/relationships/" '{"source": { "path": "src_svm:"}, "destination": { "path": "dst_svm:"}}'
Creating a SnapMirror relationship in order to restore from a destination.
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}, "restore": "true"}'
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}, "create_destination": { "enable": "true" }}'
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}, "create_destination": { "enable": "true", "tiering": { "supported": "true", "policy": "auto" } } }'
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}, "create_destination": { "enable": "true", "storage_service": { "enabled": "true", "name": "extreme", "enforce_performance": "true" } } }'
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:", "cluster": { "name": "cluster_src" }}, "destination": { "path": "dst_svm:"}, "create_destination": { "enable": "true" }}'
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
validate_only |
boolean |
query |
False |
Validate the operation and its parameters, without actually performing the operation. |
Request Body
| Name | Type | Description |
_links |
create_destination |
Use this object to provision the destination endpoint when establishing a SnapMirror relationship for a FlexVol volume, FlexGroup volume, or SVM. Given a source endpoint, the destination endpoint is provisioned in the SVM specified in the "destination.path" property. The SVM destination endpoint can only be provisioned on the local cluster. To provision the SVM destination endpoint use the optional "source.cluster.name" property to specify the remote cluster name or use the optional "source.cluster.uuid" property to specify the remote cluster UUID. When "create_destination.enabled" option is specified while making a POST for a SnapMirror relationship, the relationship can be automatically initialized by setting the "state" either to "snapmirrored" when the policy is of type "async" or to "in_sync" when the policy is of type "sync". The "destination.path" property must specify the destination endpoint path. For example, for FlexVol volume and FlexGroup volume, the "destination.path" can be specified as
destination |
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume or FlexGroup volume endpoints can optionally specify the "cluster" property. A POST request to establish a SnapMirror relationship when the source SVM and the destination SVM are not peered, must specify the "cluster" property. |
exported_snapshot |
string |
Snapshot copy exported to clients on destination. |
healthy |
boolean |
Is the relationship healthy? |
lag_time |
string |
Time since the exported Snapshot copy was created. |
policy |
Basic policy information of the relationship. |
preserve |
boolean |
Set to true on resync to preserve Snapshot copies on the destination that are newer than the latest common Snapshot copy. This property is applicable only for relationships with FlexGroup or FlexVol endpoints and when the PATCH state is being changed to "snapmirrored". |
quick_resync |
boolean |
Set to true to reduce resync time by not preserving storage efficiency. This property is applicable only for relationships with FlexVol endpoints and when the PATCH state is being changed to "snapmirrored". |
recover_after_break |
boolean |
Set to true to recover from a failed SnapMirror break operation on a FlexGroup relationship. This restores all destination FlexGroup constituents to the latest Snapshot copy, and any writes to the read-write constituents are lost. This property is applicable only for SnapMirror relationships with FlexGroup endpoints and when the PATCH state is being changed to "broken_off". |
restore |
boolean |
Set to true to create a relationship for restore. To trigger restore-transfer, use transfers POST on the restore relationship. |
restore_to_snapshot |
string |
Specifies the Snapshot copy to restore to on the destination during the break operation. This property is applicable only for SnapMirror relationships with FlexVol endpoints and when the PATCH state is being changed to "broken_off". |
source |
state |
string |
State of the relationship. To initialize the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or "in-sync" for relationships with a policy of type "sync". To break the relationship, PATCH the state to "broken_off". To resync the broken relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or "in_sync" for relationships with a policy of type "sync". To pause the relationship, suspending further transfers, PATCH the state to "paused". To resume transfers for a paused relationship, PATCH the state to "snapmirrored" or "in_sync". The entries "in_sync", "out_of_sync", and "synchronizing" are only applicable to relationships with a policy of type "sync". A PATCH call on the state change only triggers the transition to the specified state. You must poll on the "state", "healthy" and "unhealthy_reason" properties using a GET request to determine if the transition is successful. To automatically initialize the relationship when specifying “create_destination”, set the state to “snapmirrored” for relationships with a policy of type "async" or "in_sync" for relationships with a policy of type "sync". |
transfer |
Basic information on the current transfer. |
unhealthy_reason |
array[snapmirror_error] |
Reason the relationship is not healthy. It is a concatenation of up to four levels of error messages. |
uuid |
string |
Example request
"href": "/api/resourcelink"
"name": "string"
"tiering": {
"policy": "string"
"destination": {
"cluster": {
"name": "cluster1",
"ipspace": "Default",
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"exported_snapshot": "string",
"lag_time": "PT8H35M42S",
"policy": {
"name": "Asynchronous",
"type": "string",
"restore_to_snapshot": "string",
"source": {
"cluster": {
"name": "cluster1",
"svm": {
"name": "svm1",
"state": "snapmirrored",
"transfer": {
"state": "string",
"unhealthy_reason": [
"code": "6621444",
"message": "Failed to complete update operation on one or more item relationships.",
"parameters": []
"code": "6621445",
"message": "Group Update failed",
"parameters": []
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
6620374 |
Internal error. Failed to get SVM information. |
6620478 |
Internal error. Failed to check SnapMirror capability. |
13303819 |
Could not retrieve SnapMirror policy information. |
13303821 |
Invalid SnapMirror policy UUID. |
13303841 |
This operation is not supported for SnapMirror relationships between these endpoints. |
13303852 |
destination.path provided does not contain \":\". |
13303853 |
Restore relationships are not supported for SVM-DR endpoints. |
13303868 |
Create of destination endpoint and SnapMirror relationship failed. |
13303869 |
Creating a destination endpoint is not supported for restore relationships. |
13303870 |
A tiering policy cannot be specified if tiering is not being set to supported. |
13303871 |
Storage service properties cannot be specified if the storage service is not being enabled. |
13303872 |
Specified property requires a later effective cluster version. |
13303873 |
Specifying a state when creating a relationship is only supported when creating a destination endpoint. |
13303874 |
Specified state is not supported when creating this relationship. |
13303875 |
Destination aggregates do not have sufficient space for hosting copies of source volumes. |
13303876 |
Destination cluster does not have composite aggregates. |
13303877 |
Source or destination cluster must be specified. |
13303878 |
The specified fields do not match. |
13303879 |
Source cluster name or UUID is needed to provision a destination SVM on the local cluster. |
13303880 |
Source cluster must be remote for provisioning a destination SVM on the local cluster. |
13303881 |
Network validation failed. |
13303882 |
SVM validation failed. |
13303883 |
Encryption is not enabled on the destination cluster. |
13303887 |
Synchronous SnapMirror relationships between FlexGroup volumes are not supported. |
13303888 |
Synchronous SnapMirror relationships require an effective cluster version of 9.5 or later on both the source and destination clusters. |
13303889 |
Asynchronous SnapMirror relationships between FlexGroup volumes require an effective cluster version of 9.5 or later on both the source and destination clusters. |
13303890 |
Asynchronous SnapMirror relationships between FlexVol volumes require an effective cluster version of 9.3, 9.5, or later on both the source and destination clusters. |
13303891 |
Creating a destination endpoint with storage service requires an effective cluster version of 9.7 or later. |
13303892 |
Fetching remote information from the destination cluster failed. |
13303893 |
Updating job description failed. |
13303894 |
Destination volume name is invalid. It must contain the source volume name and have a suffix when creating a destination endpoint on a cluster with an effective cluster version of 9.6 or earlier. |
13303895 |
Operation on the remote destination cluster is not supported. |
13303916 |
FlexGroup volumes are not supported on SnapLock aggregates. |
13303918 |
No suitable destination aggregate type is available. |
13303919 |
Only FabricPool enabled aggregates are available on the destination. |
13303920 |
Only SnapLock aggregates are available on the destination. FlexGroup volumes are not supported on SnapLock aggregates. |
13303921 |
Unable to retrieve the SnapMirror capabilities of the destination cluster. |
13303922 |
Specified source SVM is not a data SVM. |
13303923 |
Specified destination SVM is not a data SVM. |
13303924 |
Source SVM has an invalid Snapshot copy policy. |
13303925 |
SnapMirror validation has failed. |
13303930 |
The specified tiering policy is not supported for destination volumes of Synchronous relationships. |
13303938 |
Fetching information from the local cluster failed. |
13303939 |
Could not create an SVM peer relationship. |
13303944 |
An SVM-DR relationship is not supported because the source SVM has CIFS configured and the associated SnapMirror policy has either the identity_preservation property not set or set to exclude_network_and_protocol_config. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
storage_service
enabled |
boolean |
This property indicates whether to create the destination endpoint using storage service. |
enforce_performance |
boolean |
Optional property to enforce storage service performance on the destination endpoint when the destination endpoint is used for read-write operations. This property is applicable to FlexVol volume and FlexGroup volume endpoints. |
name |
string |
Optional property to specify the storage service name for the destination endpoint. This property is considered when the property "create_destination.storage_service.enabled" is set to "true". When the property "create_destination.storage_service.enabled" is set to "true" and the "create_destination.storage_service.name" for the endpoint is not specified, then ONTAP selects the highest storage service available on the cluster to provision the destination endpoint. This property is applicable to FlexVol volume and FlexGroup volume endpoints.
tiering
policy |
string |
Optional property to specify the destination endpoint's tiering policy when "create_destination.tiering.supported" is set to "true". This property is applicable to FlexVol volume and FlexGroup volume endpoints. This property determines whether the user data blocks of the destination endpoint in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of the destination endpoint volume blocks increases if they are accessed frequently and decreases when they are not. all ‐ This policy allows tiering of both destination endpoint Snapshot copies and the user transfered data blocks to the cloud store as soon as possible by ignoring the temperature on the volume blocks. This tiering policy is not applicable for synchronous relationships. auto ‐ This policy allows tiering of both destination endpoint Snapshot copies and the active file system user data to the cloud store none ‐ Destination endpoint volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the destination endpoint volume Snapshot copies not associated with the active file system. The default tiering policy is "snapshot_only" for a FlexVol volume and "none" for a FlexGroup volume. |
supported |
boolean |
Optional property to enable provisioning of the destination endpoint volumes on FabricPool aggregates. This property is applicable to FlexVol volume and FlexGroup volume endpoints. Only FabricPool aggregates are used if this property is set to "true" and only non FabricPool aggregates are used if this property is set to "false". Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only do the destination endpoint volumes need to support tiering by using FabricPools, the "create_destination.tiering.policy" must not be "none". A destination endpoint that uses FabricPools but has a tiering "policy" of "none" supports tiering but will not tier any data. |
snapmirror_destination_creation
enabled |
boolean |
Optional property to create the destination endpoint when establishing a SnapMirror relationship. It is assumed to be "false" if no other property is set and assumed to be "true" if any other property is set. |
storage_service |
tiering |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
cluster |
ipspace |
string |
Optional property to specify the IPSpace of the SVM. |
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1:
svm |
policy
_links |
name |
string |
type |
string |
uuid |
string |
transfer
_links |
bytes_transferred |
integer |
Bytes transferred. |
state |
string |
uuid |
string |
snapmirror_error
SnapMirror error
code |
integer |
Error code |
message |
string |
Error message |
parameters |
array[string] |
Parameters for the error message |
snapmirror_relationship
SnapMirror relationship information
_links |
destination |
exported_snapshot |
string |
healthy |
boolean |
lag_time |
string |
policy |
preserve |
boolean |
quick_resync |
boolean |
boolean |
restore |
boolean |
string |
source |
state |
string |
transfer |
unhealthy_reason |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
