Create a clone of the file
POST /storage/file/clone
Creates a clone of the file.
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
autodelete |
boolean |
Mark clone file for auto deletion. |
destination_path |
string |
Relative path of the clone/destination file in the volume. |
is_backup |
boolean |
Mark clone file for backup. |
overwrite_destination |
boolean |
Destination file gets overwritten. |
range |
array[string] |
List of block ranges for sub-file cloning in the format "source-file-block-number:destination-file-block-number:block-count" |
source_path |
string |
Relative path of the source file in the volume. |
volume |
Example request
"destination_path": "dest_file1, dir1/dest_file2",
"range": [
36605,
73210
"source_path": "src_file1, dir1/src_file2, ./.snapshot/snap1/src_file3",
"volume": {
"href": "/api/resourcelink"
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
file_clone
File clone
autodelete |
boolean |
destination_path |
string |
is_backup |
boolean |
boolean |
range |
array[string] |
source_path |
string |
volume |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
