Create a SnapLock log configuration for an SVM
POST /storage/snaplock/audit-logs
Creates a SnapLock log configuration for an SVM. A SnapLock log configuration consists of a volume to store the log, the maximum size of the log file, and the default period of time for which the log file should be retained. The input parameter retention_period expects the duration in ISO 8601 format.
Required properties
svm.uuidorsvm.name- Name or UUID of the SVM. -
log_volume.volume.nameorlog_volume.volume.uuid- Name or UUID of audit log volume.
Recommended optional properties
log_volume.max_log_size- Max log file size. -
log_volume.volume.retention_period- Retention period of log file.
Default property values
If not specified in POST, the following default property values are assigned:
log_volume.retention_period- P6M -
log_volume.max_log_size- 10MB
Related ONTAP commands
snaplock log create
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
log_archive |
log_files |
array[snaplock_log_file] |
log_volume |
svm |
Example request
"href": "/api/resourcelink"
"log_archive": {
"base_name": "string",
"expiry_time": "2058-06-04 19:00:00 UTC",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": 20000
"log_files": [
"size": 20000
"log_volume": {
"max_log_size": 20971520,
"retention_period": "P30M",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090340 |
{field} is a required field |
14090343 |
Invalid Field |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
log_archive
_links |
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
snaplock_log_file
_links |
archive |
boolean |
base_name |
string |
expiry_time |
string |
path |
string |
size |
integer |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
snaplock_log_volume
_links |
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_log
_links |
log_archive |
log_files |
log_volume |
svm |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
