REST API reference
Creates a fingerprint computation session on the file and returns a session-id this session-id is a unique identifier that you can use to retrieve the progress of an ongoing fingerprint operation when the operation is complete, you can use the session-id to retrieve the complete fingerprint output for the file
  • volumename or volumeuuid - name or uuid of the volume
  • path - path of the file # default property values if not specified in post, the follow default property values are assigned:
  • algorithm - md5 # related ontap commands
  • volume file fingerprint start # example <br/>
post "/api/storage/snaplock/file-fingerprints" {"svm":{"uuid":"23940494-3f3a-11e9-8675-0050568e8f89"},"volume": {"uuid":"26cdb58c-3f3a-11e9-8675-0050568e8f89"},"path":"/vol/a1txt","algorithm":"md5"}
<br/> # learn more * [doc /storage/snaplock/file-fingerprints](#docs-snaplock-storage_snaplock_file-fingerprints)
POST /storage/snaplock/file-fingerprints
Creates a fingerprint computation session on the file and returns a session-id. This session-id is a unique identifier that you can use to retrieve the progress of an ongoing fingerprint operation. When the operation is complete, you can use the session-id to retrieve the complete fingerprint output for the file .
Required properties
  • svm.uuid or svm.name - Name or UUID of the SVM.
  • volume.name or volume.uuid - Name or UUID of the volume.
  • path - Path of the file.
Default property values
If not specified in POST, the follow default property values are assigned:
  • algorithm - md5
Example
POST "/api/storage/snaplock/file-fingerprints" '{"svm":{"uuid":"23940494-3f3a-11e9-8675-0050568e8f89"},"volume": {"uuid":"26cdb58c-3f3a-11e9-8675-0050568e8f89"},"path":"/vol/a1.txt","algorithm":"md5"}'
return_timeout
integer
query
False
return_records
boolean
query
False
Request Body
Name Type Description
_links
_links
algorithm
string
The digest algorithm which is used for the fingerprint computation
data_fingerprint
string
The digest value of data of the file. The fingerprint is base64 encoded. This field is not included if the scope is metadata-only.
file_size
integer
The size of the file in bytes.
file_type
string
The type of the file.
id
integer
A unique identifier for the fingerprint operation
metadata_fingerprint
string
The digest value of metadata of the file. The metadata fingerprint is calculated for file size, file ctime, file mtime, file crtime, file retention time, file uid, file gid, and file type. The fingerprint is base64 encoded. This field is not included if the scope is data-only.
path
string
Specifies the path on which file fingerprint operation is running or has completed. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.
scope
string
The scope of the file which is used for the fingerprint computation
state
string
Specifies the status of fingerprint operation.
svm
svm
volume
volume
Example request
      "href": "/api/resourcelink"
  "algorithm": "sha256",
  "data_fingerprint": "MOFJVevxNSJm3C/4Bn5oEEYH51CrudOzZYK4r5Cfy1g=",
  "file_size": 1048576,
  "file_type": "worm",
  "id": 17039367,
  "metadata_fingerprint": "8iMjqJXiNcqgXT5XuRhLiEwIrJEihDmwS0hrexnjgmc=",
  "path": "/homedir/dir1",
  "scope": "data_only",
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
14090443
Invalid volume name
14090444
Invalid Vserver name
14090447
Invalid volume UUID
14090448
Invalid key values. Provide valid Vserver name and volume name or Vserver UUID and volume UUID
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
snaplock_file_fingerprint
_links
_links
algorithm
string
data_fingerprint
string
file_size
integer
file_type
string
id
integer
string
path
string
scope
string
state
string
svm
svm
volume
volume
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
