REST API reference
Creates or removes litigations for the specified path
  • lhoperationpath - litigation path # related ontap commands
  • snaplock legal-hold begin
  • snaplock legal-hold end # learn more
  • [doc /storage/snaplock/litigations/{litigationid}/operations](#docs-snaplock-storage_snaplock_litigations_{litigationid}_operations)
POST /storage/snaplock/litigations/{litigation.id}/operations
Creates or removes litigations for the specified path.
Required properties
  • lh_operation.type - Legal-Hold operation type.
  • lh.operation.path - Litigation path.
return_records
boolean
query
False
litigation.id
string
path
True
Litigation ID
Request Body
Name Type Description
_links
_links
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
Example request
      "href": "/api/resourcelink"
  "id": 16842759,
  "num_files_failed": 0,
  "num_files_processed": 30,
  "num_files_skipped": 10,
  "num_inodes_ignored": 10,
  "path": "/dir1",
  "state": "completed"
Status: 201, Created
_links
_links
id
integer
Operation ID.
num_files_failed
string
num_files_processed
string
num_files_skipped
string
num_inodes_ignored
string
path
string
state
string
  "id": 16842759,
  "path": "/dir1",
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
14090343
Invalid Field
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
id
integer
Operation ID.
num_files_failed
string
num_files_processed
string
num_files_skipped
string
num_inodes_ignored
string
path
string
state
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
