Start a legal-hold operation
POST /storage/snaplock/litigations
Starts a Legal-Hold.
Required properties
path- Path of the file. -
name- Litigation name. -
volume.nameorvolume.uuid- Name or UUID of the volume.
Related ONTAP commands
snaplock legal-hold begin
Example
POST "/api/storage/snaplock/litigations" '{"volume.name":"SLC1","name":"l3","path":"/b.txt"}'
Learn more
return_records  |
boolean  |
query  |
False  |
The default is false. If set to true, the records are returned.  |
Request Body
| Name | Type | Description |
_links  |
id  |
string  |
Specifies the litigation ID.  |
name  |
string  |
Specifies the legal-hold litigation name.  |
operations  |
path  |
string  |
Specifies the path on which legal-hold operation has to be applied.  |
svm  |
volume  |
Example request
      "href": "/api/resourcelink"
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": 16842759,
      "num_files_failed": 0,
      "num_files_processed": 30,
      "num_files_skipped": 10,
      "num_inodes_ignored": 10,
      "path": "/dir1",
      "state": "completed"
  "path": "/dir1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 201, Created
_links  |
id  |
string  |
name  |
string  |
operations  |
path  |
string  |
svm  |
volume  |
  "id": "string",
  "name": "lit1",
  "operations": [
      "id": 16842759,
      "path": "/dir1",
  "path": "/dir1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346  |
Internal Error. Wait a few minutes, then try the command again  |
14090340  |
{field} is a required field  |
14090343  |
Invalid Field  |
14090641  |
The specified volume.name and volume.uuid refer to different volumes  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
snaplock_legal_hold_operation
_links  |
id  |
integer  |
Operation ID.  |
num_files_failed  |
string  |
Specifies the number of files on which legal-hold operation failed.  |
num_files_processed  |
string  |
Specifies the number of files on which legal-hold operation was successful.  |
num_files_skipped  |
string  |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.  |
num_inodes_ignored  |
string  |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.  |
path  |
string  |
Specifies the path on which legal-hold operation is applied.  |
state  |
string  |
Specifies the status of legal-hold operation.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
volume
_links  |
name  |
string  |
The name of the volume.  |
uuid  |
string  |
snaplock_litigation
_links  |
id  |
string  |
name  |
string  |
operations  |
path  |
string  |
svm  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
